跳转到主内容
How to Fix a Dirty Censor in a Corsair Harpoon RGB
你所需要的
  1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 1 中的图像 1,2 How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 1 中的图像 2,2
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 2 中的图像 1,3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 2 中的图像 2,3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 3 中的图像 1,1
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 4 中的图像 1,2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 4 中的图像 2,2
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 5 中的图像 1,2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: 步骤 5 中的图像 2,2
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
结论
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3等其他人完成本指南。
2条评论
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - 回复
why did you opened it if you just cleaned eye with alcohol
antoncoinz - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 165
总计 5,941
