跳转到主内容
How to Fix a Dent in a Hardside Suitcase
你所需要的
  1. How to Fix a Dent in a Hardside Suitcase, How to Fix a Dent in a Hardside Suitcase: 步骤 1 中的图像 1,1
    • Before you begin, determine which tool is best to use for tapping out the dent, as this depends on the size of the dent. For this guide, the handle of a screwdriver was used, but a soft mallet would work well too.
  2. How to Fix a Dent in a Hardside Suitcase: 步骤 2 中的图像 1,1
    • Use the hair dryer on the dented area for a duration of 3 minutes.
    • Move the hair dryer around the dented area to avoid heat damage to your suitcase. Wear heat-resistant gloves and check the area periodically to ensure it is not overheating.
  3. How to Fix a Dent in a Hardside Suitcase: 步骤 3 中的图像 1,2 How to Fix a Dent in a Hardside Suitcase: 步骤 3 中的图像 2,2
    • Open the suitcase and use a screwdriver handle or soft mallet to tap out the dent about 3-5 times.
    • The screwdriver is being used to shape the dent back to its original shape towards the outside of the luggage.
  4. How to Fix a Dent in a Hardside Suitcase: 步骤 4 中的图像 1,1
    • Use a hair dryer to apply heat to the dented area for 1-3 minutes, moving the heat over the area in a circular motion.
    • This will soften the suitcase material so it's easier to tap out the dent.
  5. How to Fix a Dent in a Hardside Suitcase: 步骤 5 中的图像 1,1
    • Use a screwdriver handle or soft mallet to tap the dent back to the original shape or as close to it as possible. Hit the dent using your tool about 4-6 times.
  6. How to Fix a Dent in a Hardside Suitcase: 步骤 6 中的图像 1,1
    • The process is complete and the suitcase is back to its normal shape and can be used!
结论
Samirah
于02/02/24注册
138 声望
撰写一个指南
团队
York University, Team M-8, Allen Winter 2024 York University, Team M-8, Allen Winter 2024 的会员
YORK-ALLEN-W24SMG8
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 20
过去 30 天: 97
总计 2,466
