跳转到主内容
How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard
你所需要的
  1. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 1 中的图像 1,3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 1 中的图像 2,3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard, How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 1 中的图像 3,3
    • Unplug the cord from the wall and the back of the keyboard.
  2. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 2 中的图像 1,3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 2 中的图像 2,3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 2 中的图像 3,3
    • Flip over the keyboard.
    • Check the battery holder and remove the battery cover.
    • Remove all outer screws with a Philips screwdriver. These are the 19.0 mm Philips screws.
    • Remove the middle screw and the middle top screw. They are the 25.4 mm Philips screws.
  3. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 3 中的图像 1,1
    • Carefully remove the cover, and set it aside.
    • Find the contact pad.
  4. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 4 中的图像 1,3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 4 中的图像 2,3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 4 中的图像 3,3
    • At the top of the contact pad, carefully pinch the black clamps closed.
    • Once all the clamps are closed, wiggle the contact pad free.
    • Be careful of the small black hooks at the bottom.
  5. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 5 中的图像 1,1
    • After the contact pad is free, gently lift it up.
  6. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 6 中的图像 1,3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 6 中的图像 2,3 How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 6 中的图像 3,3
    • Vacuum and/or gently wipe the dust away.
  7. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 7 中的图像 1,1
    • Place the contact pad back gently.
  8. How to Fix a Dead Key on a Yamaha PSR-280 Piano Keyboard: 步骤 8 中的图像 1,1
    • Place the cover back on.
    • Place the screws back in.
    • The 25.4mm Philips screws go in the middle and top middle. The 19mm screws go around the case.
结论
2等其他人完成本指南。
Sydney Schuett
于07/20/20注册
211 声望
撰写一个指南
团队
UW Tacoma, Team S1-G14, Cardinal Summer 2020 UW Tacoma, Team S1-G14, Cardinal Summer 2020 的会员
UWT-CARDINAL-SU20S1G14
1 名成员
创作了1篇指南
一条评论
This is a good pictorial guide to how the keyboard works and how to service it, I used electronic switch cleaner {aerosol} on a cloth to clean the contacts and it was successful leaving all the keys working.
jeff may - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 44
总计 2,924
