跳转到主内容
How to Fix a Damaged VHS Tape
你所需要的
  1. How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: 步骤 1 中的图像 1,3 How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: 步骤 1 中的图像 2,3 How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: 步骤 1 中的图像 3,3
    • Remove the screws at the bottom of the VHS case using a Phillips #0 screwdriver.
  2. How to Fix a Damaged VHS Tape: 步骤 2 中的图像 1,2 How to Fix a Damaged VHS Tape: 步骤 2 中的图像 2,2
    • Lift open the cover of the VHS.
  3. How to Fix a Damaged VHS Tape: 步骤 3 中的图像 1,2 How to Fix a Damaged VHS Tape: 步骤 3 中的图像 2,2
    • Remove the top cover of the VHS case.
  4. How to Fix a Damaged VHS Tape: 步骤 4 中的图像 1,3 How to Fix a Damaged VHS Tape: 步骤 4 中的图像 2,3 How to Fix a Damaged VHS Tape: 步骤 4 中的图像 3,3
    • Replace any rollers that accidently fall out of the VHS case.
  5. How to Fix a Damaged VHS Tape: 步骤 5 中的图像 1,3 How to Fix a Damaged VHS Tape: 步骤 5 中的图像 2,3 How to Fix a Damaged VHS Tape: 步骤 5 中的图像 3,3
    • Unroll the video tape from each side of the VHS, running it through the rollers the correct way. Do this until you reach the damaged parts of the tape.
  6. How to Fix a Damaged VHS Tape: 步骤 6 中的图像 1,3 How to Fix a Damaged VHS Tape: 步骤 6 中的图像 2,3 How to Fix a Damaged VHS Tape: 步骤 6 中的图像 3,3
    • Cut out the wrinkled and damaged parts of the VHS tape using scissors.
  7. How to Fix a Damaged VHS Tape: 步骤 7 中的图像 1,1
    • Hold the undamaged parts of the tape over each other as evenly as possible.
  8. How to Fix a Damaged VHS Tape: 步骤 8 中的图像 1,2 How to Fix a Damaged VHS Tape: 步骤 8 中的图像 2,2
    • Cut the overlapping portion of the tape at an angle.
  9. How to Fix a Damaged VHS Tape: 步骤 9 中的图像 1,2 How to Fix a Damaged VHS Tape: 步骤 9 中的图像 2,2
    • Apply scotch tape to the dull side of the two matching halves of the VHS tape.
    • Potential for device damage: Do not wrap the scotch tape around the other side of the VHS tape.
  10. How to Fix a Damaged VHS Tape: 步骤 10 中的图像 1,3 How to Fix a Damaged VHS Tape: 步骤 10 中的图像 2,3 How to Fix a Damaged VHS Tape: 步骤 10 中的图像 3,3
    • Cut excess scotch tape to match the size of the VHS tape as precisely as possible.
  11. How to Fix a Damaged VHS Tape: 步骤 11 中的图像 1,3 How to Fix a Damaged VHS Tape: 步骤 11 中的图像 2,3 How to Fix a Damaged VHS Tape: 步骤 11 中的图像 3,3
    • Wind the loose VHS tape back into the case.
  12. How to Fix a Damaged VHS Tape: 步骤 12 中的图像 1,3 How to Fix a Damaged VHS Tape: 步骤 12 中的图像 2,3 How to Fix a Damaged VHS Tape: 步骤 12 中的图像 3,3
    • Replace the cover back on top of the VHS case.
  13. How to Fix a Damaged VHS Tape: 步骤 13 中的图像 1,3 How to Fix a Damaged VHS Tape: 步骤 13 中的图像 2,3 How to Fix a Damaged VHS Tape: 步骤 13 中的图像 3,3
    • Reinsert the screws through the bottom of the VHS tape.
终点
2等其他人完成本指南。
团队
3指南评论
Na het monteren van de tape, en voor het sluiten van de cassette hield ik nog een klein zwart onderdeeltje over en kan het niet meer herplaatsen, deel omdat de behuizing nagenoeg zwart is, en ook omdat ik niets wil forceren. Zou een tip om de plaats van dit onderdeel te vinden enorm op prijs stellen.
Jan - 回复
Inmiddels van iemand een VHS band geleend, opengemaakt en vastgesteld waar het blokje past, bij de afbeelding 4 en 5 is dat helaas slecht te zien, maar het blokje past in een kleine ruimte tussen de twee spoelen. Het zou mooi zijn, als je plaatjes kon toevoegen, maar goed probleem opgelost, en nu opnieuw met de videograbber aan de slag, wat leveren de Kabelshop en NEDIS een slecht service, door steeds verwijzen dat het aan de kabel ligt, de videospeler, of de aansluiting met de Windows PC, feitelijk stijllloos.
Jan - 回复
domz - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 40
过去 30 天: 187
总计 12,089
