跳转到主内容
How to Fix a Crooked Cabinet
你所需要的
  1. How to Fix a Crooked Cabinet, Examine the Issue: 步骤 1 中的图像 1,3 How to Fix a Crooked Cabinet, Examine the Issue: 步骤 1 中的图像 2,3 How to Fix a Crooked Cabinet, Examine the Issue: 步骤 1 中的图像 3,3
    • Examine which door needs to be adjusted and to what extent. In this example, we start the adjustment with the lower screws of the cabinet door.
  2. How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: 步骤 2 中的图像 1,3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: 步骤 2 中的图像 2,3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: 步骤 2 中的图像 3,3
    • Hold onto the cabinet as you unscrew the two bottom screws to reposition it.
    • Select the appropriate screwdriver bit.
    • Tighten the screws to adjust appropriately.
  3. How to Fix a Crooked Cabinet, Repeat with the Top Screws: 步骤 3 中的图像 1,3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: 步骤 3 中的图像 2,3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: 步骤 3 中的图像 3,3
    • Repeat Step 2 with the screws at the top.
  4. How to Fix a Crooked Cabinet, Adjust to Gap: 步骤 4 中的图像 1,1
    • The gap should be even from top to bottom. Ensure that it is and hold the cabinet in place to adjust if it is not.
  5. How to Fix a Crooked Cabinet, Feel Accomplished: 步骤 5 中的图像 1,2 How to Fix a Crooked Cabinet, Feel Accomplished: 步骤 5 中的图像 2,2
    • You've done it! As long as the gap is even, your results should be just like this.
    • Great job!
终点
3等其他人完成本指南。
Elmore Smith
于11/20/22注册
196 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 29
过去 30 天: 154
总计 3,411
