跳转到主内容
How to Fix a Crack in a Hollow Wood Door
你所需要的
  1. How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: 步骤 1 中的图像 1,2 How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: 步骤 1 中的图像 2,2
    • Clean and dust the affected area with a paper towel, rag, or brush.
  2. How to Fix a Crack in a Hollow Wood Door: 步骤 2 中的图像 1,1
    • Sand the affected area with a 60/80 grit sanding sponge.
    • Any type of sand paper or sanding sponge will work on wood surfaces.
    • It is recommended to place newspaper under the door to keep the sand/dust contained.
  3. How to Fix a Crack in a Hollow Wood Door: 步骤 3 中的图像 1,1
    • Remove any sand/dust with a paper towel.
    • It is recommend to use gloves to prevent any minor splinters.
    • It is also recommended to use a face mask to prevent inhaling any dust/sand.
  4. How to Fix a Crack in a Hollow Wood Door: 步骤 4 中的图像 1,1
    • Use putty knife to apply body filler until an even layer is formed.
    • Start with a small amount and then add more if needed.
    • A smaller putty knife allows for easier application in creases and folds.
  5. How to Fix a Crack in a Hollow Wood Door: 步骤 5 中的图像 1,1
    • Remove any excess body filler with putty knife
    • Its okay if the surface is uneven, you will use sandpaper to smooth the surface in a later step.
  6. How to Fix a Crack in a Hollow Wood Door: 步骤 6 中的图像 1,1
    • Allow to dry (or use a blow dryer for lesser wait time).
    • More expensive brands of body filler will dry faster.
  7. How to Fix a Crack in a Hollow Wood Door: 步骤 7 中的图像 1,2 How to Fix a Crack in a Hollow Wood Door: 步骤 7 中的图像 2,2
    • Gently sand the surface.
    • Gloves and a face mask are highly recommended but not required for this step.
    • Newspaper is also recommended to contain any sand/dust.
    • Reapply body filler, allow to dry, and re-sand if surface remains uneven.
  8. How to Fix a Crack in a Hollow Wood Door: 步骤 8 中的图像 1,1
    • Use a similar toned paint to paint the area if any discoloration exists.
    • Wood paint is ideal for wood doors.
  9. How to Fix a Crack in a Hollow Wood Door: 步骤 9 中的图像 1,1
    • Allow to dry.
    • Your door should now look neutral and clean.
    • A blow dryer is recommended for faster drying.
结论
3等其他人完成本指南。
Lea Thomas
于01/20/19注册
250 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 49
过去 7 天: 284
过去 30 天: 1,544
总计 136,409
