跳转到主内容
How to Fix a Chair Armrest
你所需要的
  1. How to Fix a Chair Armrest, How to Fix a Chair Armrest: 步骤 1 中的图像 1,3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: 步骤 1 中的图像 2,3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: 步骤 1 中的图像 3,3
    • Remove the armrest from the chair using a hex wrench screwdriver and a drill to remove the screws.
    • You can also use a screwdriver instead of a drill.
  2. How to Fix a Chair Armrest: 步骤 2 中的图像 1,2 How to Fix a Chair Armrest: 步骤 2 中的图像 2,2
    • This is the chair that we will fix, and the armrest that was broken.
  3. How to Fix a Chair Armrest: 步骤 3 中的图像 1,2 How to Fix a Chair Armrest: 步骤 3 中的图像 2,2
    • Sand just the inside tip of the armrest as shown.
  4. How to Fix a Chair Armrest: 步骤 4 中的图像 1,2 How to Fix a Chair Armrest: 步骤 4 中的图像 2,2
    • Apply a little bit of glue on the part that you sanded.
    • It is fine if you do not want to use glue.
  5. How to Fix a Chair Armrest: 步骤 5 中的图像 1,2 How to Fix a Chair Armrest: 步骤 5 中的图像 2,2
    • Put the screw washer on the screw.
  6. How to Fix a Chair Armrest: 步骤 6 中的图像 1,3 How to Fix a Chair Armrest: 步骤 6 中的图像 2,3 How to Fix a Chair Armrest: 步骤 6 中的图像 3,3
    • Insert the screw inside the hole on the inside of the chair body.
    • Have another person attach the armrest and then screw it with your hand.
  7. How to Fix a Chair Armrest: 步骤 7 中的图像 1,2 How to Fix a Chair Armrest: 步骤 7 中的图像 2,2
    • Insert the screw into the end of the armrest, attaching it to the edge of the back of the chair using a drill.
    • You may also use a screwdriver instead of a drill.
  8. How to Fix a Chair Armrest: 步骤 8 中的图像 1,3 How to Fix a Chair Armrest: 步骤 8 中的图像 2,3 How to Fix a Chair Armrest: 步骤 8 中的图像 3,3
    • Tighten up the screw with a hex wrench screwdriver.
  9. How to Fix a Chair Armrest: 步骤 9 中的图像 1,2 How to Fix a Chair Armrest: 步骤 9 中的图像 2,2
    • All done! Now your armrest should feel securely attached to the chair.
结论
These are moderate step to fix your chair armrest.
另外一个人完成了本指南。
Deviny
于03/23/21注册
196 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 52
总计 2,601
