跳转到主内容
How to Fix a Cabinet Door Hinge with a Damaged Base
你所需要的
  1. How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: 步骤 1 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: 步骤 1 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base, Hinge: 步骤 1 中的图像 3,3
    • Choose the correct screwdriver to remove the damaged hinge.
    • A properly sized bit should “fill up” the screw head, utilizing both the full depth and width of the socket.
    • In general, use the largest bit size that fits snugly into the screw.
  2. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 2 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 2 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 2 中的图像 3,3
    • If the door is still attach to the cabinet, use your screwdriver to remove the screws from the door hinges.
    • Take the doors off the cabinets before you begin the repair.
  3. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 3 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 3 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 3 中的图像 3,3
    • Remove all of the screws from the first hinge of the cabinet.
  4. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 4 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 4 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 4 中的图像 3,3
    • Remove all the the screws from the second hinge of the cabinet.
  5. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 5 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 5 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 5 中的图像 3,3
    • Remove all of the screws from the door hinge.
  6. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 6 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 6 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 6 中的图像 3,3
    • Squeeze the wood filler in the damaged base of the cabinet.
    • Some wood fillers require you to mix them with hardener. For those types, add 1/3 amount of hardener with filler and mix them until a consistent texture. Then apply the mixture to the damaged area. For more clarity, watch this video.
    • Place a card beside the hole and fill the hole with wood filler.
    • Overfill the damaged base slightly, to ensure the hole is filled completely.
  7. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 7 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 7 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 7 中的图像 3,3
    • Scrape the extra filler from the base with a putty knife or stiff card to smooth the surface before it dries.
    • Leave the filler for 20 to 30 minutes to dry.
  8. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 8 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 8 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 8 中的图像 3,3
    • Place the cabinet hinge repair plate on the new base and secure with the screws that are included in the kit.
    • Make sure the plate is properly aligned with existing holes.
  9. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 9 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 9 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 9 中的图像 3,3
    • Place the new cabinet hinge on the repair plate and screw it in with a drill.
    • Note that the size of hinges and screws may vary according to the individual's need.
  10. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 10 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 10 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 10 中的图像 3,3
    • If the base was only pulled out on one side, then simply screw the new hinge on the other side.
    • If the base was pulled out, use the wood filler technique and repair plate on both sides.
  11. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 11 中的图像 1,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 11 中的图像 2,3 How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 11 中的图像 3,3
    • Using your screwdriver, attach the door to the cabinet.
    • Make sure the door is level and aligned with the other door.
  12. How to Fix a Cabinet Door Hinge with a Damaged Base: 步骤 12 中的图像 1,1
    • Test the door multiple times by opening and closing it.
    • Congratulations, the door is now fixed!
终点
6等其他人完成本指南。
团队
York University, Team M-24, Allen Summer 2022 York University, Team M-24, Allen Summer 2022 的会员
YORK-ALLEN-SU22SMG24
1 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 31
过去 7 天: 187
过去 30 天: 883
总计 42,224
