简介
The weather can be unexpected; therefore, it is important to always have an umbrella handy. Over time, umbrellas can sometimes break or not function properly. This guide will provide the necessary steps to fix a push-up button in an umbrella. It is a simple process that requires a thin piece of copper and permanent adhesive.
In step four be careful not to apply adhesive to your fingers, similarly, be mindful in step six when sliding the handle on, as you could accidentally pinch yourself.
你所需要的
Remove the 1.1 mm screw that fixates the handle to the umbrella using a Phillips #1 screwdriver.
结论
