跳转到主内容
How to Fix a Brother DCP-7060N Paper Jam
  1. How to Fix a Brother DCP-7060N Paper Jam, How to Fix a Brother DCP-7060N Paper Jam: 步骤 1 中的图像 1,2 How to Fix a Brother DCP-7060N Paper Jam, How to Fix a Brother DCP-7060N Paper Jam: 步骤 1 中的图像 2,2
    • Press the power button on the side of the printer to turn it off.
  2. How to Fix a Brother DCP-7060N Paper Jam: 步骤 2 中的图像 1,1
    • Wait for ten minutes or until the printer has cooled down completely.
    • Touch the top cover to make sure the temperature has cooled down.
  3. How to Fix a Brother DCP-7060N Paper Jam: 步骤 3 中的图像 1,2 How to Fix a Brother DCP-7060N Paper Jam: 步骤 3 中的图像 2,2
    • Open the front tray carefully.
    • Check the status of the three rollers. If there is a paper jam, pull the paper out carefully.
  4. How to Fix a Brother DCP-7060N Paper Jam: 步骤 4 中的图像 1,3 How to Fix a Brother DCP-7060N Paper Jam: 步骤 4 中的图像 2,3 How to Fix a Brother DCP-7060N Paper Jam: 步骤 4 中的图像 3,3
    • Pull two sides at the position in the photo to open the front cover.
    • Remove the drum from two sides in the position in the photo.
    • Draw out the toner at the photo position.
  5. How to Fix a Brother DCP-7060N Paper Jam: 步骤 5 中的图像 1,1
    • Check inside if there is paper jam.
    • If there is a paper jam, carefully remove the paper with two hands and ensure there is nothing else inside.
  6. How to Fix a Brother DCP-7060N Paper Jam: 步骤 6 中的图像 1,3 How to Fix a Brother DCP-7060N Paper Jam: 步骤 6 中的图像 2,3 How to Fix a Brother DCP-7060N Paper Jam: 步骤 6 中的图像 3,3
    • Turn the printer around.
    • Open the back cover of the printer at the position in photo.
    • Remove the back cover and check the status inside.
    • If there is a paper jam, take out the paper along the exit direction carefully.
  7. How to Fix a Brother DCP-7060N Paper Jam: 步骤 7 中的图像 1,2 How to Fix a Brother DCP-7060N Paper Jam: 步骤 7 中的图像 2,2
    • Close all covers and consumables bin.
结论
3等其他人完成本指南。
KehaoWu
于01/15/22注册
224 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 96
总计 3,192
