跳转到主内容
How to Fix a Broken Vertical Blind for Sliding Glass Door
你所需要的
  1. How to Fix a Broken Vertical Blind for Sliding Glass Door, How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 1 中的图像 1,2 How to Fix a Broken Vertical Blind for Sliding Glass Door, How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 1 中的图像 2,2
    • Remove the broken hanging blind slat from the holding piece at the top of the blind.
    • In this case, it was clear the slat was broken because there was tape needed to hold it on.
  2. How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 2 中的图像 1,2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 2 中的图像 2,2
    • Use scissors and cut the end of the slat just beneath the hole so it looks neater and a new hole can be made beneath it.
  3. How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 3 中的图像 1,2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 3 中的图像 2,2
    • Use a ruler and pencil and mark halfway in between the two long sides.
    • In this case, the mark was made at 1.75 inches from each side.
  4. How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 4 中的图像 1,2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 4 中的图像 2,2
    • Use the ruler and pencil again, and go along the center line, down about 3/8 inch and put a dot.
    • In this particular case, about 3/8 inches works best however it could vary depending on the blinds.
  5. How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 5 中的图像 1,2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 5 中的图像 2,2
    • Use the hole puncher and make a hole through the dot you just made on the blind slat.
  6. How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 6 中的图像 1,2 How to Fix a Broken Vertical Blind for Sliding Glass Door: 步骤 6 中的图像 2,2
    • Replace the hanging slat back into the holding piece on the blinds.
    • Be careful in this step once again so as to not break the plastic piece or the newly fixed blind slat once again.
结论
Your vertical blinds are now fixed and hanging properly, looking brand new!
2等其他人完成本指南。
Andrew Sheedy
于03/22/21注册
173 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 132
总计 6,871
