跳转到主内容
加入维修社区 - 创建账户
How to Fix a Broken Toilet Paper Holder
你所需要的
  1. How to Fix a Broken Toilet Paper Holder, How to Fix a Broken Toilet Paper Holder: 步骤 1 中的图像 1,1
    • As you can tell, the left holder is loose. Replacing the anchor is much needed.
    询问修复机器人
    添加评论
  2. How to Fix a Broken Toilet Paper Holder: 步骤 2 中的图像 1,1
    • Remove the Allen screw under each holder.
    • I used a 1/6" Allen bit because that is what fit my toilet paper holder's Allen screw. Use the bit according to the screw available.
    • If the screw size is unknown, I would recommend buying a pack with several Allen bits and trying each until the right one is found.
    询问修复机器人
    添加评论
  3. How to Fix a Broken Toilet Paper Holder: 步骤 3 中的图像 1,3 How to Fix a Broken Toilet Paper Holder: 步骤 3 中的图像 2,3 How to Fix a Broken Toilet Paper Holder: 步骤 3 中的图像 3,3
    • After unscrewing the holder, take it off and begin unscrewing the screws in the wall. The type of screwdriver depends on the screws used.
    • Remove the clip after removing all screws. You should be left with two big holes and two small holes in the wall.
    询问修复机器人
    添加评论
  4. How to Fix a Broken Toilet Paper Holder: 步骤 4 中的图像 1,2 How to Fix a Broken Toilet Paper Holder: 步骤 4 中的图像 2,2
    • Remove the existing anchor and drill the top hole with the 5/16" drill bit. This will make space for the new anchor to be placed.
    • Pinch the new 3/8"-1/2" anchor, place it into the top hole, and push it to be level with the wall.
    询问修复机器人
    添加评论
  5. How to Fix a Broken Toilet Paper Holder: 步骤 5 中的图像 1,2 How to Fix a Broken Toilet Paper Holder: 步骤 5 中的图像 2,2
    • After placing the new anchor in, align the clip accordingly and proceed to screw in the anchor, starting with the top hole and then the bottom hole.
    • You have the option to use a either a screwdriver or drill (head based on the screws in possession).
    询问修复机器人
    添加评论
  6. How to Fix a Broken Toilet Paper Holder: 步骤 6 中的图像 1,2 How to Fix a Broken Toilet Paper Holder: 步骤 6 中的图像 2,2
    • When you have completed the previous step for both sides, place the toilet paper holder in place and re-screw the Allen screw until both holders feel stiff.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 52
过去 30 天: 211
总计 29,803
