简介
If your pair of Gaoye Blue Light Eyeglasses has a broken or cleaved temple arm, use this guide to discover a technique to help repair and reassemble the temple arm.
The temple arm on a pair of Gaoye Blue Light Eyeglasses is a part of the frame that supports the glass's lenses. When the temple arm is cleaved unintentionally by destructive actions of users, pets, or children, users cannot place the Gaoye glasses over their ears, and the glasses will not serve their function.
The purpose of this guide is to lead you through steps that you can take to reassemble the broken section of the temple arm on a pair of Gaoye Blue Light Eyeglasses. The guide's use of both glue and a heat-shrinking tube also ensures the longevity of the repair.
Be sure to take safety precautions when utilizing a handheld hair dryer to apply the heat-shrinking tube to the temple arm of the Gaoye Blue Light Eyeglasses. This step can be dangerous if you point the hair dryer at others or yourself. Additionally, when using the hair dryer, you should remove any flammable objects from your surroundings.
你所需要的
Apply dish soap to the broken temple arm sections.
Scrub the broken temple arm sections with the dish soap for one minute.
