跳转到主内容
How to Fix a Broken Seam on Pants
你所需要的
  1. How to Fix a Broken Seam on Pants, Locate the repair area: 步骤 1 中的图像 1,3 How to Fix a Broken Seam on Pants, Locate the repair area: 步骤 1 中的图像 2,3 How to Fix a Broken Seam on Pants, Locate the repair area: 步骤 1 中的图像 3,3
    • Identify the part of the pants that needs repairing and gather all the necessary tools.
  2. How to Fix a Broken Seam on Pants, Pin the area: 步骤 2 中的图像 1,3 How to Fix a Broken Seam on Pants, Pin the area: 步骤 2 中的图像 2,3 How to Fix a Broken Seam on Pants, Pin the area: 步骤 2 中的图像 3,3
    • Use sewing pines or needles to pin the seam area and hold it together for the next step.
  3. How to Fix a Broken Seam on Pants, Clean the area: 步骤 3 中的图像 1,2 How to Fix a Broken Seam on Pants, Clean the area: 步骤 3 中的图像 2,2
    • Once the area has been fixed with the pins, use a seam ripper to remove the old threads.
    • If there are still any remaining loose threads, use a pair scissors to cut them.
  4. How to Fix a Broken Seam on Pants, Start stitching: 步骤 4 中的图像 1,3 How to Fix a Broken Seam on Pants, Start stitching: 步骤 4 中的图像 2,3 How to Fix a Broken Seam on Pants, Start stitching: 步骤 4 中的图像 3,3
    • Use a sewing machine to stitch the marked area.
    • Finish up the stitch by cutting any loose threads with a pair of scissors.
  5. How to Fix a Broken Seam on Pants, Finished and ready!: 步骤 5 中的图像 1,3 How to Fix a Broken Seam on Pants, Finished and ready!: 步骤 5 中的图像 2,3 How to Fix a Broken Seam on Pants, Finished and ready!: 步骤 5 中的图像 3,3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
团队
INTERSPORT INTERSPORT 的会员
Community
25 名成员
创作了169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 49
总计 612
