跳转到主内容
How to Fix a Broken Seam in a Camping Chair
你所需要的
  1. How to Fix a Broken Seam in a Camping Chair, Identify the repair area: 步骤 1 中的图像 1,3 How to Fix a Broken Seam in a Camping Chair, Identify the repair area: 步骤 1 中的图像 2,3 How to Fix a Broken Seam in a Camping Chair, Identify the repair area: 步骤 1 中的图像 3,3
    • Locate the broken seam that needs to be fixed.
  2. How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: 步骤 2 中的图像 1,3 How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: 步骤 2 中的图像 2,3 How to Fix a Broken Seam in a Camping Chair, Unscrew the back of the chair: 步骤 2 中的图像 3,3
    • Use a screwdriver to disassemble the back support and set aside the screws and remaining parts.
  3. How to Fix a Broken Seam in a Camping Chair, Clean the area: 步骤 3 中的图像 1,3 How to Fix a Broken Seam in a Camping Chair, Clean the area: 步骤 3 中的图像 2,3 How to Fix a Broken Seam in a Camping Chair, Clean the area: 步骤 3 中的图像 3,3
    • Using a pair of scissors and a "seam ripper" remove the loose threads.
  4. How to Fix a Broken Seam in a Camping Chair, Start sewing: 步骤 4 中的图像 1,3 How to Fix a Broken Seam in a Camping Chair, Start sewing: 步骤 4 中的图像 2,3 How to Fix a Broken Seam in a Camping Chair, Start sewing: 步骤 4 中的图像 3,3
    • Sew along the "dotted line" following the direction of the red arrow. This is the path where the previous stitch used to be.
    • Note: in this example, the original seam used to have 2 lines of stitches, this is why a second line of stitches is needed to reinforce the area.
  5. How to Fix a Broken Seam in a Camping Chair, Clean the loose threads: 步骤 5 中的图像 1,2 How to Fix a Broken Seam in a Camping Chair, Clean the loose threads: 步骤 5 中的图像 2,2
    • Using a pair of scissors cut the remaining threads to clean the area.
  6. How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: 步骤 6 中的图像 1,3 How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: 步骤 6 中的图像 2,3 How to Fix a Broken Seam in a Camping Chair, Reassemble the chair: 步骤 6 中的图像 3,3
    • Start by putting the components back, first the repaired fabric and then the rest of the parts.
    • Tip: make sure the holes in the metal part of the chair match the holes of the fabric (orange circles).
    • Screw back the pieces that were taken on the previous steps.
  7. How to Fix a Broken Seam in a Camping Chair, Finished and ready!: 步骤 7 中的图像 1,2 How to Fix a Broken Seam in a Camping Chair, Finished and ready!: 步骤 7 中的图像 2,2
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
团队
INTERSPORT INTERSPORT 的会员
Community
25 名成员
创作了169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 17
总计 700
