跳转到主内容
How to Fix a Broken Necklace
你所需要的
  1. How to Fix a Broken Necklace, How to Fix a Broken Necklace: 步骤 1 中的图像 1,1
    • Lay your chain necklace on a flat surface.
    • This will keep the chain from tangling.
  2. How to Fix a Broken Necklace: 步骤 2 中的图像 1,1
    • Locate the broken link.
    • Place the pliers on the right of the small opening on the chain.
    • Keep your hand a few centimeters lower than the opening of the chain to avoid accidental injuries.
  3. How to Fix a Broken Necklace: 步骤 3 中的图像 1,1
    • Pull one side of the link down slightly to make the gap in the chain larger using the pliers.
    • This opens up the chain allowing you to work with it easily.
  4. How to Fix a Broken Necklace: 步骤 4 中的图像 1,2 How to Fix a Broken Necklace: 步骤 4 中的图像 2,2
    • Repeat step three on the opposite side of the chain.
  5. How to Fix a Broken Necklace: 步骤 5 中的图像 1,2 How to Fix a Broken Necklace: 步骤 5 中的图像 2,2
    • Take both ends of the chain and hook them together.
  6. How to Fix a Broken Necklace: 步骤 6 中的图像 1,2 How to Fix a Broken Necklace: 步骤 6 中的图像 2,2
    • Close the chain by using the pliers to push the link to its original position.
  7. How to Fix a Broken Necklace: 步骤 7 中的图像 1,1
    • Repeat step six to close the other chain link.
  8. How to Fix a Broken Necklace: 步骤 8 中的图像 1,1
    • Your jewelry is ready to be worn!
结论
This creative guide can be used for all accessories whether big or small, wide or thin. Now you can restore old, broken, accessories that still have a special place in your heart.
4等其他人完成本指南。
Salonee
于04/09/15注册
263 声望
撰写一个指南
团队
Cal Poly, Team 28-4, Green Spring 2015 Cal Poly, Team 28-4, Green Spring 2015 的会员
CPSU-GREEN-S15S28G4
6 名成员
创作了14篇指南
2条评论
Always great to be able to repair and reuse broken jewelry. A tip on how to add a bright, metal jump ring or chain to an older, more tarnished necklace is to use the flame of a wooden match to burn the newer metal. It will give it an antique look. Try doing it on just one bit of metal to see how it reacts. And, always hold the metal with your pliers, not your hands, when you're burning it. Allow it to cool. Wipe off excess tarnish with a tissue. Note: this needs a wooden match, not a lighter.
Also, to polish sterling chains, you can use a q-tip with fireplace ashes. They work great!
janiceparsons - 回复
Fixed a broken chain bracelet with your method!
Thanks a bunch :)
Mihai Patrascu - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 3,820
