跳转到主内容
How to Fix a Broken Ceramic Vase
你所需要的
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: 步骤 1 中的图像 1,1
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: 步骤 2 中的图像 1,1
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: 步骤 3 中的图像 1,2 How to Fix a Broken Ceramic Vase: 步骤 3 中的图像 2,2
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: 步骤 4 中的图像 1,1
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: 步骤 5 中的图像 1,1
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: 步骤 6 中的图像 1,2 How to Fix a Broken Ceramic Vase: 步骤 6 中的图像 2,2
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: 步骤 7 中的图像 1,1
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: 步骤 8 中的图像 1,1
    • Let the paint dry for one hour on the vase and your repair is finished.
终点
另外一个人完成了本指南。
1指南评论
What kind of putty do you use?
Jill Martin Ward - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 34
过去 30 天: 170
总计 4,774
