跳转到主内容
How to Fix a BIC Wite-Out Mini
你所需要的
  1. How to Fix a BIC Wite-Out Mini, How to Fix a BIC Wite-Out Mini: 步骤 1 中的图像 1,1
    • Place the dispenser component with the logo facing down, with other components laid out on a clean, flat surface.
  2. How to Fix a BIC Wite-Out Mini: 步骤 2 中的图像 1,1
    • Stabilize the small gear with tweezers to prevent further unwinding.
  3. How to Fix a BIC Wite-Out Mini: 步骤 3 中的图像 1,3 How to Fix a BIC Wite-Out Mini: 步骤 3 中的图像 2,3 How to Fix a BIC Wite-Out Mini: 步骤 3 中的图像 3,3
    • Untangle the plastic strip by rotating the large gear in a circular motion, going in the opposite direction of the spiral.
    • Stop once the plastic strip connecting the gears is straight.
  4. How to Fix a BIC Wite-Out Mini: 步骤 4 中的图像 1,3 How to Fix a BIC Wite-Out Mini: 步骤 4 中的图像 2,3 How to Fix a BIC Wite-Out Mini: 步骤 4 中的图像 3,3
    • Feed the plastic strip into the small gear until the white-out strip is visible.
    • Turn the big gear toward the small gear until they are close to each other.
  5. How to Fix a BIC Wite-Out Mini: 步骤 5 中的图像 1,1
    • Place gears back into dispenser component with the logo.
    • Place the small gear onto the module closer to the dispensing slot.
    • Place the large gear onto module farthest from the dispensing slot.
  6. How to Fix a BIC Wite-Out Mini: 步骤 6 中的图像 1,1
    • Hold the white-out strip with tweezers and pull to wrap the strip around the dispensing slot.
    • Make sure to stabilize the gears.
  7. How to Fix a BIC Wite-Out Mini: 步骤 7 中的图像 1,3 How to Fix a BIC Wite-Out Mini: 步骤 7 中的图像 2,3 How to Fix a BIC Wite-Out Mini: 步骤 7 中的图像 3,3
    • Wrap the black band around both gears.
    • If necessary, stabilize the large gear with tweezers.
    • Wrap the band starting from large gear to small gear.
  8. How to Fix a BIC Wite-Out Mini: 步骤 8 中的图像 1,2 How to Fix a BIC Wite-Out Mini: 步骤 8 中的图像 2,2
    • Close the device until the side components click closed.
结论
Congrats! You have just successfully repaired your BIC Wite-Out Mini!
Test your BIC Wite-Out Mini to make sure that it works correctly. If it does not work, repeat steps 1-8 and try again!
Lauren Miller
于01/31/24注册
157 声望
撰写一个指南
团队
UC Davis, Team 3-1, Andersen Winter 2024 UC Davis, Team 3-1, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S3G1
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 38
过去 30 天: 148
总计 1,796
