跳转到主内容
How to Fix Xbox 360 Controller Joystick Drift
你所需要的
  1. How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: 步骤 1 中的图像 1,2 How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: 步骤 1 中的图像 2,2
    • Remove seven screws from the back of the controller using a T8 Torx screwdriver.
  2. How to Fix Xbox 360 Controller Joystick Drift: 步骤 2 中的图像 1,2 How to Fix Xbox 360 Controller Joystick Drift: 步骤 2 中的图像 2,2
    • Remove the back to see the motherboard.
    • Do this with caution as it could easily be damaged if wires disconnect.
  3. How to Fix Xbox 360 Controller Joystick Drift: 步骤 3 中的图像 1,2 How to Fix Xbox 360 Controller Joystick Drift: 步骤 3 中的图像 2,2
    • Gently dab a cotton swab with isopropyl or rubbing alcohol to the joystick in a circular motion.
    • Be careful when adding liquid; too much liquid can damage the controller.
  4. How to Fix Xbox 360 Controller Joystick Drift: 步骤 4 中的图像 1,2 How to Fix Xbox 360 Controller Joystick Drift: 步骤 4 中的图像 2,2
    • Use a blow dryer to dry both the left and right joysticks.
结论
8等其他人完成本指南。
Luis Ramirez
于08/25/22注册
288 声望
撰写一个指南
5指南评论
This is not a genuine Xbox 360 controller and you truly aren't doing anything at all. You haven't even removed the thumbsticks to service the internals of the sensor assembly lol.
Alexander Dimitrov - 回复
Hi, I did this with a genuine controller and it completely worked for me. I just wiped the metal frames and went round the inside-joystick that I could, with the Q-tip.
ShadowNinja5764 - 回复
is replacing a joystick on a Xbox 360 wireless controller the same as replacing a joystick on a PowerA wired controller
batman2345 - 回复
Not sure, but i do know you need to be careful. The circuit board in the Xbox controller is very easy to damage. The pads can lift easily if not careful when desoldering. Add solder before you try to desolder.
Burned -
I believe this is a fix only for if you get premature stick drift. Stick drift from prolonged/intense use requires replacement of parts.
Wes Plants - 回复
添加评论
浏览统计数据:
过去 24 小时: 63
过去 7 天: 356
过去 30 天: 1,326
总计 39,037
