跳转到主内容
How to Fix Warped LEGO Baseplates
你所需要的
  1. How to Fix Warped LEGO Baseplates, How to Fix Warped LEGO Baseplates: 步骤 1 中的图像 1,1
    • Grab a pot large enough to place the LEGO baseplate in.
    • Fill the pot full of tap water, enough to submerge the baseplate completely.
  2. How to Fix Warped LEGO Baseplates: 步骤 2 中的图像 1,3 How to Fix Warped LEGO Baseplates: 步骤 2 中的图像 2,3 How to Fix Warped LEGO Baseplates: 步骤 2 中的图像 3,3
    • Place the pot of water on a stove.
    • Turn the stove burner on to medium heat.
    • Heat the water to approximately 100 degrees Fahrenheit. Use a thermometer to ensure proper heat.
    • Do not heat water near or above a temperature of 140 degrees Fahrenheit to avoid damaging/melting the plastic.
  3. How to Fix Warped LEGO Baseplates: 步骤 3 中的图像 1,3 How to Fix Warped LEGO Baseplates: 步骤 3 中的图像 2,3 How to Fix Warped LEGO Baseplates: 步骤 3 中的图像 3,3
    • Place the LEGO baseplate in the pot of heated water for 5-7 minutes.
    • Ensure that the LEGO baseplate is fully submerged for the entire heating duration.
  4. How to Fix Warped LEGO Baseplates: 步骤 4 中的图像 1,1
    • Turn the stove off and remove the baseplate from the water.
    • Dry the LEGO baseplate using a paper towel.
  5. How to Fix Warped LEGO Baseplates: 步骤 5 中的图像 1,1
    • Quickly sandwich the baseplate between two flat baking pans while the baseplate is still warm.
    • You can use any two flat, sturdy objects if baking pans are unavailable.
  6. How to Fix Warped LEGO Baseplates: 步骤 6 中的图像 1,2 How to Fix Warped LEGO Baseplates: 步骤 6 中的图像 2,2
    • Place two plastic clamps over the two pans to evenly apply firm pressure against the baseplate.
    • If clamps are unavailable, you can use weights to apply similar pressure.
    • Leave the LEGO baseplate in between the pressure of the baking pans for at least 5 hours.
结论
If your LEGO baseplate is still warped after the 5 hours of sitting in between the clamps, repeat process and leave the LEGO baseplate in between clamps for an additional 5 hours.
3等其他人完成本指南。
Nicole DeFer
于09/26/22注册
224 声望
撰写一个指南
团队
CSU Fullerton, Team 1-5, Bruce Fall 2022 CSU Fullerton, Team 1-5, Bruce Fall 2022 的会员
CSUF-BRUCE-F22S1G5
2 名成员
创作了3篇指南
1指南评论
100 degrees doesn't seem hot enough.
michael kithcart - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 67
总计 3,739
