跳转到主内容
How to Fix Thread Tension on a Juki DDL-8700
你所需要的
  1. How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 步骤 1 中的图像 1,3 How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 步骤 1 中的图像 2,3 How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: 步骤 1 中的图像 3,3
    • Thread the machine.
    • Insert the bobbin case.
  2. How to Fix Thread Tension on a Juki DDL-8700: 步骤 2 中的图像 1,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 2 中的图像 2,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 2 中的图像 3,3
    • Sew a straight line on scrap fabric to test thread tension.
    • Be cautious when placing your fingers near the needle when working with the machine turned on.
  3. How to Fix Thread Tension on a Juki DDL-8700: 步骤 3 中的图像 1,2 How to Fix Thread Tension on a Juki DDL-8700: 步骤 3 中的图像 2,2
    • Check the fabric for loose thread tension.
    • Look out for loops of thread on the top and bottom of the fabric.
    • The bobbin case tension is too loose if loops are on the top of the fabric.
    • The upper thread tension is too loose if the loops are on the bottom of the fabric.
  4. How to Fix Thread Tension on a Juki DDL-8700: 步骤 4 中的图像 1,2 How to Fix Thread Tension on a Juki DDL-8700: 步骤 4 中的图像 2,2
    • Take out the bobbin case.
  5. How to Fix Thread Tension on a Juki DDL-8700: 步骤 5 中的图像 1,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 5 中的图像 2,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 5 中的图像 3,3
    • Create a baseline thread tension for the bobbin case by tightening or loosening the screw on the bobbin case.
    • Thread should not easily unravel but can be pulled loosely.
  6. How to Fix Thread Tension on a Juki DDL-8700: 步骤 6 中的图像 1,2 How to Fix Thread Tension on a Juki DDL-8700: 步骤 6 中的图像 2,2
    • Reinsert the bobbin case into the machine.
  7. How to Fix Thread Tension on a Juki DDL-8700: 步骤 7 中的图像 1,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 7 中的图像 2,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 7 中的图像 3,3
    • Sew another straight line on the scrap fabric next to the previous line.
  8. How to Fix Thread Tension on a Juki DDL-8700: 步骤 8 中的图像 1,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 8 中的图像 2,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 8 中的图像 3,3
    • Check the front and back thread tension of the scrap fabric for loose stitches.
  9. How to Fix Thread Tension on a Juki DDL-8700: 步骤 9 中的图像 1,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 9 中的图像 2,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 9 中的图像 3,3
    • Adjust the upper thread tension.
    • If there are loose stitches on the top of the fabric, loosen the upper thread tension by turning the tension knob counterclockwise.
    • If there are loose stitches on the bottom of the fabric, tighten the upper thread tension by turning the tension knob clockwise.
  10. How to Fix Thread Tension on a Juki DDL-8700: 步骤 10 中的图像 1,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 10 中的图像 2,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 10 中的图像 3,3
    • Check the thread tension by sewing another straight line on the scrap fabric next to the previous line.
  11. How to Fix Thread Tension on a Juki DDL-8700: 步骤 11 中的图像 1,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 11 中的图像 2,3 How to Fix Thread Tension on a Juki DDL-8700: 步骤 11 中的图像 3,3
    • The thread tension is correct if there are no loose stitches.
    • Repeat steps 5-8 as needed to achieve a consistent thread tension without loops on top or bottom of scrap fabric.
终点
另外一个人完成了本指南。
Brandon Mammon
于11/05/24注册
214 声望
撰写一个指南
团队
UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 的会员
UCD-VIDAL-CHIESA-F24S1G9
2 名成员
创作了1篇指南
1指南评论
اَلسَلامُ عَلَيْكُم وَرَحْمَةُ اَللهِ وَبَرَكاتُهُ‎
yar khan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 76
总计 885
