跳转到主内容
How to Fix Subwoofer Amplifiers
你所需要的
  1. How to Fix Subwoofer Amplifiers, How to Fix Subwoofer Amplifiers: 步骤 1 中的图像 1,1
    • Disconnect the black (negative) cable from the battery to disable the electrical connection.
    • Always disconnect the negative cable before the positive cable.
    • Disconnect the red (positive) cable from the battery to disable the electrical connection.
  2. How to Fix Subwoofer Amplifiers: 步骤 2 中的图像 1,1
    • Pull the fuses out and make sure that they were not blown.
  3. How to Fix Subwoofer Amplifiers: 步骤 3 中的图像 1,1
    • Undo and remove all wires from the amplifier.
    • This should include the battery wire, ground wire, speaker wires, remote wire from the radio, and sound wires that also come from radio.
    • Remove and check the fuse from the amp to make sure it is not a blown fuse.
  4. How to Fix Subwoofer Amplifiers: 步骤 4 中的图像 1,1
    • Strip the wires so they can have a better connection.
    • Twist the exposed copper wiring to make it easier to connect to the amplifier.
  5. How to Fix Subwoofer Amplifiers: 步骤 5 中的图像 1,1
    • Replace the wires in their designated slots.
    • Tighten the clamps all the way down.
    • Wiggle and tug on the wires to make sure they are secured nice and tight.
  6. How to Fix Subwoofer Amplifiers: 步骤 6 中的图像 1,1
    • Replace the battery wires.
    • The red wire should go to the positive side, and the black wire should go to the negative side.
终点
另外一个人完成了本指南。
Luke Turner
于03/23/23注册
154 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 58
总计 2,039
