跳转到主内容
How to Fix Stuck Yamaha PSR-6 Keyboard Keys
你所需要的
  1. How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 1 中的图像 1,3 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 1 中的图像 2,3 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 1 中的图像 3,3
    • Turn around the keyboard with the keys facing down.
    • Remove the 15 10 mm screws using a Phillips #1 screwdriver.
    • Remove the five 12 mm screws using a Phillips #1 screwdriver.
    • Remove the extra two 10 mm screws in the bottom using a Phillips #1 screwdriver.
  2. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 2 中的图像 1,1
    • Pull the tab and remove the battery cover.
  3. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 3 中的图像 1,1
    • Take the back plate of the piano with both hands and remove it.
  4. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 4 中的图像 1,2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 4 中的图像 2,2
    • Turn around the piano with the tiles facing up.
    • Remove the speaker's cover on the left side of the keyboard.
    • Remove the plastic cover on the right side of the keyboard.
  5. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 5 中的图像 1,2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 5 中的图像 2,2
    • Flip the keyboard with the keys facing down.
    • Remove the single 12 mm screw using a Phillips #1 screwdriver.
  6. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 6 中的图像 1,1
    • Lift the front plate of the keyboard and rotate it 180°.
    • While doing this, grab the speaker with the other hand so it doesn't fall and hit the table.
  7. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 7 中的图像 1,2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 7 中的图像 2,2
    • Remove all the 10 mm screws on the top of the keys using a Phillips #1 screwdriver.
  8. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 8 中的图像 1,1
    • Use a spudger to separate the teeth to the plates that hold the keys together.
    • Do this gently as the plate may be fragile.
  9. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: 步骤 9 中的图像 1,1
    • Pull the black plate that holds the keys together horizontally away from the keys.
    • With the top of the keys exposed, use a damp cloth or wipes to clean the space between the tiles.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 14
过去 30 天: 53
总计 1,864
