跳转到主内容
How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard
你所需要的
  1. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard, How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 1 中的图像 1,1
    • Before starting the disassembly of your device, be sure to disconnect your keyboard from your computer.
    • Grab the USB-C cable with two fingers and pull it out of the port on the back of the keyboard.
    • When the keyboard's lights go out, that indicates it has been turned off properly.
  2. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 2 中的图像 1,1
    • Dip a Q-tip or cotton ball in rubbing alcohol. Any rubbing alcohol is fine.
    • Make sure the Q-tip or cotton ball isn't dripping but is very damp with the alcohol.
    • The step will require multiple Q-tips or cotton balls.
  3. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 3 中的图像 1,1
    • Using the Q-tips, rub the outside of all the keys that may be affected.
    • If the keys are really dirty, you may need to apply some force in order to scrub the grime off the keys.
  4. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 4 中的图像 1,1
    • Once you have cleaned the top of the keys with rubbing alcohol, remove the key caps from the switches using the key prying tool.
    • You may have to apply force to disconnect the caps. This is normal; no need to worry about breaking them.
  5. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 5 中的图像 1,1
    • After removing the key caps from the board, the switches will be available to clean.
  6. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 6 中的图像 1,1
    • Put any dirty key caps in a small glass with a soap and water solution and let them soak for 3 to 5 minutes.
    • Since the caps are plastic, soaking them for only a few minutes is safe.
    • Remember to let the keycaps dry after removing them from the glass. This is to make sure there no future water damage.
  7. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 7 中的图像 1,1
    • Use an electronics duster or a can of compressed air to remove any hair, dust, or crumbs that may have fallen under the key caps.
    • To be more thorough with your cleaning, make sure to apply air to the keycaps still on the keyboard to remove anything that can be hiding under those as well.
  8. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 8 中的图像 1,1
    • Using the Q-tip or cotton ball with rubbing alcohol, clean the top and around the base of the switches.
  9. How to Fix Sticky Keys on Ducky One 2 SF Mechanical Keyboard: 步骤 9 中的图像 1,1
    • To replace the key caps, line them up with the cutouts on each switch and push down.
    • Make sure to let the keyboard dry before putting the keycaps back on your switches. This is a precautionary step to prevent future damage.
    • Once you have reassembled the keys, press the ones you have repaired 5 to 10 times making sure you have cleaned and fixed them properly.
    • Remember these key caps are plastic, so you can apply a little more pressure than normal when putting them back on.
结论
To re-assemble your keyboard, put the keycaps on the correct spot of the keyboard and push down to secure the caps.
William Rhotenberry
于10/14/20注册
169 声望
撰写一个指南
团队
Texas Tech, Team S14-G10, Cowan Fall 2020 Texas Tech, Team S14-G10, Cowan Fall 2020 的会员
TTU-COWAN-F20S14G10
1 名成员
创作了2篇指南
一条评论
Hola,
tengo un ducky one 2 mini y dejo de repente de funcionar una fila de teclas desde la X a la M.
actualice el firmware al 1.10 pero sigue igual.
me puedes ayudar?
gracias.
JESS - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 133
总计 5,079
