简介
In this guide, I will show you how to fix and clean your Ducky One 2 SF mechanical keyboard (model#: DKON1967ST). If you use your keyboard daily, then you probably have encountered the sticky key problem before. It is a fairly easy problem to fix and only requires a few minutes depending on the severity of the problem. It is important to note not to over use your rubbing alcohol or water/soap solution. Since this is an electronic device, you don’t want to damage it with liquids. With that being said, there is a panel covering the wiring of the device that protects it from this problem, so make sure when cleaning, keep the Q-tips and cotton balls damp and not dripping with your cleaning solution.
你所需要的
Before starting the disassembly of your device, be sure to disconnect your keyboard from your computer.
Grab the USB-C cable with two fingers and pull it out of the port on the back of the keyboard.
To re-assemble your keyboard, put the keycaps on the correct spot of the keyboard and push down to secure the caps.
