跳转到主内容
How to Fix Stick Drift for a PlayStation Dualsense Controller V1
你所需要的
  1. How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 1 中的图像 1,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 1 中的图像 2,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 1 中的图像 3,3
    • Insert an opening tool into the bottom right corner of the controller.
    • Lift upwards with the opening tool.
    • Continue using the opening tool to pry up the inner sides of the black rim.
    • Repeat on the opposite side.
  2. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 2 中的图像 1,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 2 中的图像 2,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 2 中的图像 3,3
    • Lift the black cover upwards to remove.
  3. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 3 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 3 中的图像 2,2
    • Insert the opening tool below the L1 button and pry the button away from the controller.
  4. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 4 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 4 中的图像 2,2
    • Insert the opening tool below the R1 button and pry the button away from the controller.
  5. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 5 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 5 中的图像 2,2
    • Detach the two middle clips using the opening tool or your fingers.
  6. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 6 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 6 中的图像 2,2
    • Remove the top right and left 6.4 mm screws using a Phillips #00 screwdriver.
  7. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 7 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 7 中的图像 2,2
    • Remove the bottom right and left 6.4 mm screws using a Phillips #00 screwdriver.
  8. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 8 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 8 中的图像 2,2
    • Insert the opening tool in between the sides to open the case.
  9. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 9 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 9 中的图像 2,2
    • With both hands, pull apart the white bottom case to remove.
  10. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 10 中的图像 1,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 10 中的图像 2,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a pair of tweezers or your fingers, disconnect the battery from the motherboard.
  11. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 11 中的图像 1,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 11 中的图像 2,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 11 中的图像 3,3
    • Use tweezers or your fingers to pull the orange ribbon.
    • Remove the 6.4 mm screw using a Phillips #00 screwdriver.
    • Lift the battery bracket.
  12. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 12 中的图像 1,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 12 中的图像 2,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 12 中的图像 3,3
    • Use tweezers or your fingers to detach the four ribbons from the motherboard.
  13. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 13 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 13 中的图像 2,2
    • Guide the joysticks through the front case and lift the motherboard.
  14. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 14 中的图像 1,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 14 中的图像 2,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 14 中的图像 3,3
    • Remove the joystick covers by pulling straight off.
  15. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 15 中的图像 1,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 15 中的图像 2,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 15 中的图像 3,3
    • Use the opening tool to snap open the green tabs.
  16. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 16 中的图像 1,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 16 中的图像 2,3 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 16 中的图像 3,3
    • Use tweezers to remove the wiper disks.
  17. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 17 中的图像 1,2 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: 步骤 17 中的图像 2,2
    • Using a cotton tip with 99.8% isopropyl alcohol, clean around the black rims of the green tabs and the wiper disks.
结论
71等其他人完成本指南。
Yadsari
于11/01/23注册
2,106 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-8, Kershman Fall 2023 CSU Los Angeles, Team 4-8, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S4G8
1 名成员
创作了6篇指南
16指南评论
Just cleaning the carbon track on the potentiometer is not really a long term fix for stick drift. Better fixes would be to either replace the photometers or to replace the complete stick with a hall-effect joy stick.
David Fear - 回复
Do you have a link?
Nora -
I did it, sadly cleaning wasn't enough. So I guess I'll have to replace something.
Riedweg Guillaume - 回复
There is now a real fix for this, hall effect mod by Jun Zheng. About $25 per pair of mods. Check out the guys YouTube, link to his AliExpress store in his video description. Just use the guide here for disassembly. https://youtube.com/@junZeng-520?si=UYbf...
Alex Lao - 回复
Upon reassembly I get the three orange blinks error. Research says there’s a ribbon connection error, is that right? I went through steps again and checked all connections, but no change. Have I short circuited something? Would replacing the potentiometer even fix it at this point? Have I damaged a ribbon? (There is no visible damage).
joe lewis - 回复
添加评论
浏览统计数据:
过去 24 小时: 97
过去 7 天: 740
过去 30 天: 3,395
总计 85,476
