跳转到主内容
How to Fix Scratches on a Steel Watch
你所需要的
  1. How to Fix Scratches on a Steel Watch, How to Fix Scratches on a Steel Watch: 步骤 1 中的图像 1,1
    • Fill any container up with water.
  2. How to Fix Scratches on a Steel Watch: 步骤 2 中的图像 1,1
    • Grab any soft-bristled brush around for your convenience.
  3. How to Fix Scratches on a Steel Watch: 步骤 3 中的图像 1,3 How to Fix Scratches on a Steel Watch: 步骤 3 中的图像 2,3 How to Fix Scratches on a Steel Watch: 步骤 3 中的图像 3,3
    • Dip the toothbrush in the water.
    • Brush along the crystal, bezel, and case in a circular motion.
    • Brush the bracelet in a linear motion back-and-forth.
    • Make sure to brush over the crevices of the bracelet for an optimal clean.
  4. How to Fix Scratches on a Steel Watch: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Dry the watch with a microfiber towel by pinching your fingers together in a back-and-forth motion.
  5. How to Fix Scratches on a Steel Watch: 步骤 5 中的图像 1,1
    • Use the abrasive side of a sponge to brush the watch, following the same steps mentioned in Step 3.
    • Do not brush over the crystal with the sponge.
    • Apply minimal pressure to the sponge when brushing the watch.
  6. How to Fix Scratches on a Steel Watch: 步骤 6 中的图像 1,1
    • Fold the metal polishing cloth in half.
    • Hold the corner of the cloth along your index finger.
  7. How to Fix Scratches on a Steel Watch: 步骤 7 中的图像 1,1
    • Brush off all the scratches on the watch using a back-and-forth motion with great pressure to ensure effectiveness.
    • Perform the process as many times as needed.
    • Do not brush over the crystal.
终点
另外一个人完成了本指南。
Youssefmo
于08/31/22注册
219 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-26, Briggs Fall 2022 CSU Los Angeles, Team 2-26, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S2G26
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 32
总计 1,092
