跳转到主内容
How to Fix Sagging IKEA Lack Shelves
你所需要的
  1. How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: 步骤 1 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: 步骤 1 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves, How to Fix Sagging IKEA Lack Shelves: 步骤 1 中的图像 3,3
    • Hold the shelf on both sides and push it upwards. Slowly pull the shelf out to expose the anchored screws.
  2. How to Fix Sagging IKEA Lack Shelves: 步骤 2 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves: 步骤 2 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves: 步骤 2 中的图像 3,3
    • Pull out the loose screws and plugs to expose the holes in the wall.
    • Drill into these holes using a cordless power drill machine to even out the edge of the holes and to make sure the hole is deep enough for the new screws and plugs.
  3. How to Fix Sagging IKEA Lack Shelves: 步骤 3 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves: 步骤 3 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves: 步骤 3 中的图像 3,3
    • Apply the drywall filler into the holes and also over the holes to cover it.
    • This filler becomes hard as concrete when it dries, It will hold the screw firmly in place.
  4. How to Fix Sagging IKEA Lack Shelves: 步骤 4 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves: 步骤 4 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves: 步骤 4 中的图像 3,3
    • Smooth out the drywall filler using a taping knife.
    • Applying poly filler over the holes and smoothing it out will create an even texture and hide the edges of each hole.
  5. How to Fix Sagging IKEA Lack Shelves: 步骤 5 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves: 步骤 5 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves: 步骤 5 中的图像 3,3
    • Insert a Phillips #10 screw and plug into each hole carefully.
    • Make sure the wall plug is pushed inside entirely, only exposing the edges.
  6. How to Fix Sagging IKEA Lack Shelves: 步骤 6 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves: 步骤 6 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves: 步骤 6 中的图像 3,3
    • When the wall plug and screw is pushed into the hole, the smoothed out drywall filler will become messy around the edges.
    • Using the taping knife, carefully smooth out the drywall filler around the screws.
  7. How to Fix Sagging IKEA Lack Shelves: 步骤 7 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves: 步骤 7 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves: 步骤 7 中的图像 3,3
    • Now proceed to drive the screw into the wall plug and secure it in place.
    • Drive the screw-in until 1-1.5inch space is left between the wall and the screw head.
  8. How to Fix Sagging IKEA Lack Shelves: 步骤 8 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves: 步骤 8 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves: 步骤 8 中的图像 3,3
    • Apply more drywall filler over the edges of the wall plug to hide it.
    • Using the taping knife, smooth out the drywall filler.
    • This step may look redundant but it is necessary to secure the screw and plug firmly.
  9. How to Fix Sagging IKEA Lack Shelves: 步骤 9 中的图像 1,3 How to Fix Sagging IKEA Lack Shelves: 步骤 9 中的图像 2,3 How to Fix Sagging IKEA Lack Shelves: 步骤 9 中的图像 3,3
    • After the drywall filler hardens. it is time to insert the shelf in place.
    • Insert the round side of the hook into each screw. Then push the shelf downwards until it is level to secure it in place.
结论
The shelf is now fixed!
3等其他人完成本指南。
Sanjana Salam
于01/15/21注册
223 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 64
过去 7 天: 417
过去 30 天: 1,892
总计 86,721
