跳转到主内容
加入维修社区 - 创建账户
How to Fix Plastic Chair Cracks
你所需要的
  1. How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: 步骤 1 中的图像 1,2 How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: 步骤 1 中的图像 2,2
    • Lay the broken chair such that the crack is parallel to the floor.
    询问修复机器人
    添加评论
  2. How to Fix Plastic Chair Cracks: 步骤 2 中的图像 1,2 How to Fix Plastic Chair Cracks: 步骤 2 中的图像 2,2
    • Wear gloves to minimize chemical contact on skin.
    • Dampen a rag with isopropyl alcohol.
    询问修复机器人
    添加评论
  3. How to Fix Plastic Chair Cracks: 步骤 3 中的图像 1,2 How to Fix Plastic Chair Cracks: 步骤 3 中的图像 2,2
    • Clean the surface of the crack with the dampened rag to remove all dust and debris.
    • Repeat on all sides of the crack (edges and backside).
    询问修复机器人
    添加评论
  4. How to Fix Plastic Chair Cracks: 步骤 4 中的图像 1,3 How to Fix Plastic Chair Cracks: 步骤 4 中的图像 2,3 How to Fix Plastic Chair Cracks: 步骤 4 中的图像 3,3
    • Apply glue between the crack.
    • Then apply glue across the surface of the crack.
    询问修复机器人
    添加评论
  5. How to Fix Plastic Chair Cracks: 步骤 5 中的图像 1,1
    • Hold the two glued pieces together for 30 seconds to allow the glue to bind to the chair.
    • Do not let the glue dry completely. The wet glue will need to bind with baking soda in the next step.
    询问修复机器人
    添加评论
  6. How to Fix Plastic Chair Cracks: 步骤 6 中的图像 1,3 How to Fix Plastic Chair Cracks: 步骤 6 中的图像 2,3 How to Fix Plastic Chair Cracks: 步骤 6 中的图像 3,3
    • Pour baking soda over the crack until the glue is completely covered under a layer of baking soda.
    添加评论
  7. How to Fix Plastic Chair Cracks: 步骤 7 中的图像 1,2 How to Fix Plastic Chair Cracks: 步骤 7 中的图像 2,2
    • Use your finger to distribute the baking soda in order to cover all parts of the crack.
    询问修复机器人
    添加评论
  8. How to Fix Plastic Chair Cracks: 步骤 8 中的图像 1,3 How to Fix Plastic Chair Cracks: 步骤 8 中的图像 2,3 How to Fix Plastic Chair Cracks: 步骤 8 中的图像 3,3
    • Allow the baking soda to seal onto the super glue over the crack and wait for the mixture to dry.
    • After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
    添加评论
  9. How to Fix Plastic Chair Cracks: 步骤 9 中的图像 1,2 How to Fix Plastic Chair Cracks: 步骤 9 中的图像 2,2
    • Flip the chair over.
    • Repeat the procedure on the backside of the crack starting from step 4 and ending with step 8.
    • Avoid reapplying glue in between crack, since it has already been sealed.
    询问修复机器人
    添加评论
  10. How to Fix Plastic Chair Cracks: 步骤 10 中的图像 1,2 How to Fix Plastic Chair Cracks: 步骤 10 中的图像 2,2
    • Remove excess baking soda from both the front and back side of the crack.
    • Use water or isopropyl alcohol to remove fine grains around the repair site.
    询问修复机器人
    添加评论
  11. How to Fix Plastic Chair Cracks: 步骤 11 中的图像 1,1
    • Sand off any excess layers of glue on both the front and backside of the chair using coarse sandpaper.
    • This step is optional and simply helps to return the chair to its original look.
    • It may take a while to rid the chair of all texture.
    询问修复机器人
    添加评论
  12. How to Fix Plastic Chair Cracks: 步骤 12 中的图像 1,1
    • The crack has been repaired!
    添加评论
终点
取消:我没有完成这个指南。
20等其他人完成本指南。
团队
UC Davis, Team S2-G7, Andersen Winter 2020 UC Davis, Team S2-G7, Andersen Winter 2020 的会员
UCD-ANDERSEN-W20S2G7
3 名成员
创作了6篇指南
4指南评论
Do you push the baking soda down into the glue (or into the crack), or just spread evenly on the surface?
Dr John Christensen - 回复 分享
What glue did you use?
Raffaele Bianchi - 回复 分享
Lem apa yang digunakan (nama lem)
Iwan Toro - 回复 分享
There is also duct tape.
Theo Grefalda - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 148
过去 30 天: 852
总计 63,473
