跳转到主内容
How to Fix Paper Jam in Canon Pixma TR 4520
你所需要的
  1. How to Fix Paper Jam in Canon Pixma TR 4520, press Stop to cancel the job: 步骤 1 中的图像 1,1
    • push the stop button
  2. How to Fix Paper Jam in Canon Pixma TR 4520, turn off the printer and unplug it from the power source: 步骤 2 中的图像 1,2 How to Fix Paper Jam in Canon Pixma TR 4520, turn off the printer and unplug it from the power source: 步骤 2 中的图像 2,2
    • Press the turn off button on the printer before unplugging
  3. How to Fix Paper Jam in Canon Pixma TR 4520, remove any paper visible from the front tray: 步骤 3 中的图像 1,2 How to Fix Paper Jam in Canon Pixma TR 4520, remove any paper visible from the front tray: 步骤 3 中的图像 2,2
    • open the front tray and take a look
  4. How to Fix Paper Jam in Canon Pixma TR 4520, if it is accessible with your hands, pull out paper slowly with both hands(avoid tearing): 步骤 4 中的图像 1,1
    • If paper tears apart, remove whatever you can, we can fix the rest in the later steps
  5. How to Fix Paper Jam in Canon Pixma TR 4520, if the area Is inaccessible or paper is torn, position the printer on a side to see the rear cover: 步骤 5 中的图像 1,2 How to Fix Paper Jam in Canon Pixma TR 4520, if the area Is inaccessible or paper is torn, position the printer on a side to see the rear cover: 步骤 5 中的图像 2,2
    • Do not force the paper out
  6. How to Fix Paper Jam in Canon Pixma TR 4520, pick up home usage screwdriver with the head like shown on the picture: 步骤 6 中的图像 1,3 How to Fix Paper Jam in Canon Pixma TR 4520, pick up home usage screwdriver with the head like shown on the picture: 步骤 6 中的图像 2,3 How to Fix Paper Jam in Canon Pixma TR 4520, pick up home usage screwdriver with the head like shown on the picture: 步骤 6 中的图像 3,3
    • Take a look at the shape
  7. How to Fix Paper Jam in Canon Pixma TR 4520, look for two silver screws that hold transport unit cover from the rear end: 步骤 7 中的图像 1,2 How to Fix Paper Jam in Canon Pixma TR 4520, look for two silver screws that hold transport unit cover from the rear end: 步骤 7 中的图像 2,2
    • look at the circle annotation
  8. How to Fix Paper Jam in Canon Pixma TR 4520, untwist the screw, turn the screw into counter clockwise ("loose" direction) and keep turning the screwdriver: 步骤 8 中的图像 1,3 How to Fix Paper Jam in Canon Pixma TR 4520, untwist the screw, turn the screw into counter clockwise ("loose" direction) and keep turning the screwdriver: 步骤 8 中的图像 2,3 How to Fix Paper Jam in Canon Pixma TR 4520, untwist the screw, turn the screw into counter clockwise ("loose" direction) and keep turning the screwdriver: 步骤 8 中的图像 3,3
    • Move the screwdriver slowly until the screw comes off
  9. How to Fix Paper Jam in Canon Pixma TR 4520, repeat for the second screw: 步骤 9 中的图像 1,2 How to Fix Paper Jam in Canon Pixma TR 4520, repeat for the second screw: 步骤 9 中的图像 2,2
    • Keep your screws in a safe place
  10. How to Fix Paper Jam in Canon Pixma TR 4520, transport unit cover will become loose: 步骤 10 中的图像 1,2 How to Fix Paper Jam in Canon Pixma TR 4520, transport unit cover will become loose: 步骤 10 中的图像 2,2
    • Be gentle while removing the unit, you don't want to damage it
  11. How to Fix Paper Jam in Canon Pixma TR 4520, remove the transport unit and reveal jammed paper: 步骤 11 中的图像 1,3 How to Fix Paper Jam in Canon Pixma TR 4520, remove the transport unit and reveal jammed paper: 步骤 11 中的图像 2,3 How to Fix Paper Jam in Canon Pixma TR 4520, remove the transport unit and reveal jammed paper: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Take it out with your hands or if it is hard to grab on, pick up tweezers
  12. How to Fix Paper Jam in Canon Pixma TR 4520, put the transport unit back in its place and hold it there: 步骤 12 中的图像 1,2 How to Fix Paper Jam in Canon Pixma TR 4520, put the transport unit back in its place and hold it there: 步骤 12 中的图像 2,2
    • Grab your screwdriver and screws
  13. How to Fix Paper Jam in Canon Pixma TR 4520, put the screws back in place one at a time and turn them in clockwise direction to "tighten" them up: 步骤 13 中的图像 1,3 How to Fix Paper Jam in Canon Pixma TR 4520, put the screws back in place one at a time and turn them in clockwise direction to "tighten" them up: 步骤 13 中的图像 2,3 How to Fix Paper Jam in Canon Pixma TR 4520, put the screws back in place one at a time and turn them in clockwise direction to "tighten" them up: 步骤 13 中的图像 3,3
    • You know it is tight enough if it doesn't move anymore
终点
Ani Gurtsishvili
于10/06/20注册
217 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,073
