跳转到主内容
加入维修社区 - 创建账户
How to Fix Paint Chips or Large Scratches on a Car
你所需要的
  1. How to Fix Paint Chips or Large Scratches on a Car, How to Fix Paint Chips or Large Scratches on a Car: 步骤 1 中的图像 1,1
    • Wipe down the area of the paint chip or scratch with a damp papertowel.
    询问修复机器人
    添加评论
  2. How to Fix Paint Chips or Large Scratches on a Car: 步骤 2 中的图像 1,1
    • Place tape around anything you do not want to get paint on.
    • e.g. windows, taillights/headlights, metal decals, license plates, etc.
    询问修复机器人
    添加评论
  3. How to Fix Paint Chips or Large Scratches on a Car: 步骤 3 中的图像 1,1
    • Sand down the paint chip or scratch, including the immediate surrounding area.
    • Start with a coarse grain.
    • Then move to a fine grain to remove any sharp edges.
    • Don't sand too far out around the area. The goal of using sandpaper is to reduce any edges to prevent rusting underneath the paint, and to create a surface that the primer will stick to.
    询问修复机器人
    添加评论
  4. How to Fix Paint Chips or Large Scratches on a Car: 步骤 4 中的图像 1,1
    • Wipe down the area with a dry papertowel to remove debris.
    询问修复机器人
    添加评论
  5. How to Fix Paint Chips or Large Scratches on a Car: 步骤 5 中的图像 1,1
    • Spray the primer all over the area that was sanded. Use small strokes and spray the primer around the area.
    • Wait 10 minutes or until it feels dry when touched.
    • Add another layer or two if you can still see the edge of the paint chip or scratch.
    • The goal is to fill in the scratch or chip with primer to prevent rust.
    • Let it dry for 15-20 minutes before moving to the next step.
    询问修复机器人
    添加评论
  6. How to Fix Paint Chips or Large Scratches on a Car: 步骤 6 中的图像 1,1
    • Spray on a coat of colored paint. Use small strokes and spray the paint around the area.
    • Spraying at least 6 inches (no more than 10 inches) away from the surface will prevent paint from dripping.
    • Paint drips can be removed by gently dabbing them with a dry paper towel.
    • Allow to dry.
    • Drying time takes at least 10 minutes per coat of paint.
    • Continue adding coats and drying in between until primer cannot be seen through the paint.
    询问修复机器人
    添加评论
  7. How to Fix Paint Chips or Large Scratches on a Car: 步骤 7 中的图像 1,1
    • Spray on the clear protective coat. Use small strokes and spray the clear coat around the area.
    • Allow to dry for 10 minutes or until the area feels dry when touched.
    • Add at least 3 more coats, allowing each coat to dry in between.
    • The clear coat helps prevent rust and adds a refective texture that helps the paint job blend in.
    询问修复机器人
    添加评论
    • Remove masking tape from the car when finished.
    • If you accidentally got paint on your windows, it will come off if you scratch it with a flat razor.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
5等其他人完成本指南。
1指南评论
نحياتي لكل مجتهد ومساهم هنا
Abdullah Shaweil - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 54
过去 30 天: 265
总计 17,115
