跳转到主内容
How to Fix Loose Temples on Plastic Framed Reading Glasses
你所需要的
  1. How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 1 中的图像 1,3 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 1 中的图像 2,3 How to Fix Loose Temples on Plastic Framed Reading Glasses, How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 1 中的图像 3,3
    • Fold the temples of the glasses inwards to feel which arm has less resistence.
  2. How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 2 中的图像 1,1
    • Locate the hinge screw on the arm that had less give.
    • The steps to replace the screw will be the exact same for both hinges.
  3. How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 3 中的图像 1,1
    • Test each screwdriver until the correct fit is found.
    • You may have to test every screwdriver to find the correct fit.
    • The screwdriver that we used was the #2 mm screwdriver.
  4. How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 4 中的图像 1,3 How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 4 中的图像 2,3 How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 4 中的图像 3,3
    • Insert the correct screwdriver into the screw and gently apply pressure.
    • Turn the screwdriver counterclockwise to unscrew the screw.
  5. How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 5 中的图像 1,1
    • Match the screw from the screwdriver kit.
    • Individually insert each screw into the eyeglasses. Different glasses use different screws.
  6. How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 6 中的图像 1,1
    • Insert the correct screwdriver into the screw.
  7. How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 7 中的图像 1,3 How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 7 中的图像 2,3 How to Fix Loose Temples on Plastic Framed Reading Glasses: 步骤 7 中的图像 3,3
    • Turn the screwdriver clockwise to tighten.
    • Tighten the screw until you feel a slight resistance.
    • Do not over-tighten the screw.
终点
2等其他人完成本指南。
John
于09/28/21注册
181 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 62
过去 30 天: 267
总计 7,249
