简介
任天堂的第一批左 Joy-Con 手柄因同步问题而臭名昭著。这存在一个很小的设计缺陷,可以用一小块导电泡沫来补救,这种泡沫在家里的旧包装中就能找到!
你所需要的
视频介绍
即将完成!
要重新组装设备,请按与说明相反的顺序进行操作。
结论
11等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
9条评论
Where can i find conductive foam? I don’t understand “can often be found in old packaging around the house”. What kind of packaging?
Vishvan Bhairosingh - 回复
Hey Vishvan! A lot of electronics are packaged with conductive foam, so there’s a good chance you might have some around the house if you are the kind of person who keeps boxes from electronics you have purchased in the past. You can test any foam you find with a capacitive touchscreen (like the one on your Nintendo Switch)—if the foam registers as a touch on the screen, it is conductive.
It’s nice if you can recycle some from old packaging, because it can be tricky to find online in small quantities. It generally comes in (relatively) big blocks or sheets and you only need a tiny piece.
If you cant find any around the house, eBay is a good place to start looking!
https://www.ebay.com/sch/i.html?_from=R4...
Taylor Dixon -
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - 回复
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon -
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - 回复
