简介
在本指南中,我们将了解如何拆开设备,最常见的泄漏部件在哪里,以及如何清洁和/或更换它们。
由于Krups不再销售这些部件,此设备的备件越来越难以获得。Erzatsteil Direct大多数部件仍然可供从欧洲订购的人使用。
你所需要的
将设备背面朝上,从左侧面板开始
它与下半部分的6个剪辑相连,顶部与另外几个剪辑相连
从底部的夹子(红色箭头)开始,小心地从底部向上撬开夹子
接下来打开电源线旁边的夹子
打开面板侧面的三个夹子(橙色箭头)。锁扣夹住橙色夹子 1 和 2 中的孔。如果将它们从底座直接向外提起,它们就会松开。锁扣旁边是导销。它们在移除过程中不提供阻力。
Het linkerpaneel zit met drie klemmen vast en het rechter ook. Samen dus zes klemmen.
现在继续顶部。它在两个地方连接,有一大堆剪辑和占位符。可能需要用力将它们拉开。
首先处理底部的一排剪辑(红色箭头)
然后撬开顶行(其它红色箭头)
您现在可以移除整个左侧并将其放在一边
发生泄漏的常见位置有三个。流量测量、连接到水箱的接口组件和泵组件。
要识别其中哪些正在泄漏,只需在意想不到的地方寻找水。所有联轴器都应该完全干燥。
在三个常见的泄漏地点中,大多数源于连接器组件的钙化。由于标准解钙方法(带卫星)不接触这些部件,因此很容易堵塞,并在密封之间漏水。
当其中一个联轴器确实出现故障,或者流量测量或连接器组件破裂时,请先更换这些部件。
松开接口组件。它没有粘合或被夹子固定,所以轻微的晃动就足以拉动它。
拔出密封橡胶并过滤
仔细但彻底地清洁任何钙化遗骸的外壳、密封和过滤器。
清洁组件连接到外壳的外壳底部。从这里也移除所有钙化后的遗骸
dolce gusto mini me leaking water from bottom. how to repair thanks
starlite23 - 回复
only had 1 day.
starlite23 - 回复
The red arrows on the bottonm do not point to screws. It seems that they changed to a kind of plastic fasteners that I am unable to remove. Not without damaging them that is. Anyone knows about this change and - more important - how to loosen this parts.
As far as I know they haven’t changed the model. As mentioned in the guide, the bottom doesn’t use screws, there the red arrows point to clips. It’s enough to carefully lift them using a spudger. If the bottom of your machine differs from the pictures in this guide, a picture might help figuring out what’s different
My problem was the sealing rubber was old and had become hard and brittle. Only found the whole connector-thing to buy online, but luckily didn't have to replace the whole thing, just used the small black rubber ring from it. Leak fixed. Now I just have to deal with the air in the water system that has gotten in while waiting for parts and so on… Really old piccolo machine.
Be sure to remove air from the tubes otherwise an ertoe occurs. Red blinking light.
It mag help to grease the sealing rubber with acid-free vaseline. That solved my leakage.
要重新组装您的设备,请按相反的顺序按照以下说明操作。
49等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
26条评论
Hi Joost
Thanks for the great guide. helped to quickly get into the Coffee Maker yesterday after it stopped working. Result: A Capacitor and a Resistor kicked the bucket. Replacing the ElCO is no problem as it is a fairly standard one and (more important): the values are printed on it :)
But i am not able to decipher the value of the resistor, as most of the color bands have faded away and the parts that are still visible are not clear enough to recognize the value... and since it is broken, i can't measure its value.
so i wonder: maybe you took some close ups of the PCB when doing this guide where the resistor R105 (one onnly two NON-smd resistors on the board near the inductor coil L100 (both located on the lower right side of the PCB). From what i can see form the Picture of Step 5 and 6, both our Coffee Makers use the same revision of the PCB. If so, i would kindly ask you to share them with me... a snapshot of that resistor with all it's bands visible would be enough :-)
Hi Daniel, Glad the guide was able to help you. I did take clear pictures of the pcb luckily, but i suck at decoding resistor values. Luckily the pcb is also available as a spare part, and the supplier has really clear pictures of it, so you should be able to decipher it yourself :)
Since i can't upload images to a comment as far as i can tell, please take look here: https://res.cloudinary.com/dtk4ybaqk/ima...
Hi! Do you know if i could order the needle from somwhere? Main got broken... And also how to Change it? Thank you!
Relika
Hi, it depends on the exact model, but a good place to start would be erzatsteil. A quick search gives you that there are only three models available, so just find the right one for your model number at: (https://ersatzteildirect.de/advanced_sea...). The injector plates are sold seperately, and should cost you less than 12 euros (without shipping).
Luckily, replacing it is very easy. Take a look at this guide, it will tell you how: How to fix water leaking from the side of the capsules
Hi Joost, very clear instructions, thanks. One small problem: the bolts in my machine look like Torx bolts, except that they have a little pin in the centre. That means that you need a Torx screwdriver with a hollowed out centre and I have no idea how I can get hold of those ...
As an afterthought: if scale on the connector assy is the most frequently occurring problem, I think that I'll just soak a handkerchief in a vinegar/water solution, put it on the connector and leave it overnight. See if that works.
Great tutorial, thanks! Would you happen to have a part number for the o-ring seal for the connector assembly?
Thanks!
Hello Joost. I see you have a dutch name. So maybe you could also answer me in dutch. I have problems with step 3 of your instruction. Which tool do I need to open it and remove the screw. Or in dutch: Welk gereedschap/schroevendraaier heb ik nodig om de schroeven te kunnen verwijderen.
Mireille
Hoi Mireille, Dit zijn zogenaamde Torx secure schroeven, een versie van de wat gewonere torx schroeven met een extra puntje in het midden zodat 'normale' schroevendraaiers niet passen. In dit geval gaat het specifiek om de Torx secure maat 10 (Officiele aanduiding: TR10). Je kan deze schroevendraaiers soms wat lastig vinden in de standaard bouwmarkten e.d., maar online worden ze ruim verkocht (waaronder via ifixit zelf). Voor de rest van de stappen heb je in principe geen schroevendraaier meer nodig, alhoewel in mijn ervaring het soms handig kan zijn om de lipjes goed open te krijgen. Hier zou ik dan wel een gewone platte schroevendraaier voor gebruiken, of bij voorkeur een kunststof spateltje
Dag Joost, bij mij gaat de lip om de cassette vrij te maken niet meer omhoog, zit muurvast geklemd. Ging heel soepel dicht.
Dus nu kan de cassettehouder er niet meer uit. Weet jij een oplossing?
Dank, Hans
Hans Swaab - 回复
Hi Joost,
This article even helped me repairing the KP120. Well, it helped me opening it. Those 2 pesky clips on the bottom were holding me up quite a while…
Thanks!
Hi Joost
My EDG455.B Delonghi does not pump water into the machine (the little water flow pump is not working). I tried to connect it first to a 3v and then to a 9v battery to see if it is the pump or the circuit but the pump still didn’t work. However the magnet side of the wire connecting to the board felt warm/hot after having it connected to the 9v battery. Can you think of any resolution? Thanks in advance!
Thank you! I just fixed my Dolce Gusto piccolo following these instructions. The water tank was leaking from the base, after opening it everything seemed fine. I cleaned it all but it was still leaking. I decided to put an extra fine in the bottom and now it does not leak anymore. Perhaps not the most professional of fixes, but it works now. Dankuwel meneer!
Hi, I am not having any leaking problems, but I do have a problem either with the pump or heater. My Genio 2 doesn’t stop vibrating even if I turn it off. And after getting my cup filled, water still flows onto my cup even though it has clicked. If I remove the water container from the Genio and put it back, the water flow stops, but the vibration doesn’t. I really hope you could help out.
PS: This happened after washing my Genio because there were a lot of ants. I have washed Mini Me and Drop before and didn’t encounter any problem.
Hi, my Mini Me stopped working. I did notice a water outage at the base but nothing that made me concerned much. However, I am not sure what the Spring at the rear is for (ie. what function it has) since I found it somehow dangling out and completely came off. When I plug to wall outlet, the top red button comest on for a couple of seconds, then becomes green for another second then completely switches off. Any ideas what’s going on please?
Many Thanks - Paul
Hi Paul,
The first part of you question is simple. The spring that’s at the rear is used to clear the puncher that makes the hole in the capsules. It can get clogged, and the spring is the right diameter to clear it.
The other part of your question is more complicated, since it has probably nothing to do with leakage, but with an electronics problem. Unfortunately i can’t help you with the electronics themselves without having the device there to measure which component is failing.
Thanks so much, saved my Kp110 from landfill. Leaking badly but just needed cleaning up around the connector assembly, very easy to do.
davidmoir1 - 回复
in my case the defect is not to start the pump. When the coffee maker is switched on, the red LED flashes when pressing it flashes green and heats the boiler, the lever held for a while then disarms but at no time does the pump start. I have already tested the pump by feeding it directly with 110V and it works. I just tested the NTC for coffee makers and heaters at ~ 20ºC, it's at 100k ohms, heating up or NTC I got to 1 Ohm and cooling past 100K Ohms. The NTC is working correctly, are these values OK? I measured the hfe of the triac (soldered on the plate) at the pump outlet and it looks good (0.577). The problem started because it was 110V and was connected to 220V.
Bonjour,
J ai un souci avec ma machine à café qui ne fait pas couler le café malgré le bruit de la pompe. J ai essayé le détartrage et tout mais rien ne change !
Bonne journée
Hallo, ich habe das Gerät geöffnet. Bei mir läuft kein Wasser mehr und ich finde den Fehler nicht. Filter und Dichtung sind sauner kein Leck im Innengehäuse. Motor läuft, kommt kein Wasser……
Wer kann mir helfen?
cweinzierl - 回复
Du musst halt den Wasserweg prüfen. Eventuell den Schlauch von der Pumpe abziehen, einen längeren aufstecken und gaaaanz kurz (!!!!) -größte Vorsicht- testen, ob es spritzt. Dann weiß man, dass die Pumpe nicht die Ursache ist. Eventuell ist der Durchlauferhitzer verkalkt, kommt in Gegenden mit hartem Wasser schon vor.
VauWeh -
Super Anleitung Danke Dir hat alles geglabt alles in Ordnung
My genio 2 toggle stick cant move to cold or hot. It wont automatic stop. Have to hold it. How to fix it? Thanks
Mijne loopt niet over als ik bijv. De melk cup gebruik van de latte machiatto. Maar wel bij de koffie versie van die. En hij maakt de cups helemaal niet meer leeg. Is er dan hetzelfde aan de hand als hier waar ik dat mee zou op kunnen lossen of?
Fugaciouss - 回复
hallo
weet je ook welke draad ik moet onderbreken om een diode tussen te solderen om mijn dolce gusto van 1400 watt naar 700 watt te verminderen
groetjes Chris
The “Spring” is actually the tool for cleaning obstructions from the spike that punctures the pods.
Andrew White - 回复
où trouver le tourniveis
André-Louis GUIDROUX - 回复
