跳转到主内容
How to Fix Keurig K75 Platinum Brewing System Water Pump Leak
你所需要的
  1. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, Baseplate: 步骤 1 中的图像 1,2 How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, Baseplate: 步骤 1 中的图像 2,2
    • Before beginning the repair, turn off the brewer and disconnect it from any power source.
    • Move the brewer so that the metal baseplate is easily accessible.
    • Remove the five silver 4 mm Phillips #2 screws from the baseplate.
  2. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: 步骤 2 中的图像 1,2 How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: 步骤 2 中的图像 2,2
    • Using a spudger, gently pry the metal baseplate from the brewer.
    • Gently set down the baseplate.
  3. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: 步骤 3 中的图像 1,2 How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: 步骤 3 中的图像 2,2
    • Remove the two silver 4mm Phillips #2 screws that hold the water pump in place.
  4. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: 步骤 4 中的图像 1,1
    • Realign the rubber gasket of the water pump to create a tight fit.
结论
另外一个人完成了本指南。
Kristen Temnyk
于01/24/13注册
515 声望
创作了3篇指南
团队
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 19
总计 21,638
