跳转到主内容
How to Fix Error 20
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
  1. How to Fix Error 20, Remove Debris: 步骤 1 中的图像 1,1
    • Check to make sure there is nothing physically preventing the shutter from opening.
    • Do not touch the mirror. You will leave fingerprints.
  2. How to Fix Error 20, The Battery: 步骤 2 中的图像 1,1
    • Remove the battery and wait 30 seconds.
    • Put the battery back in.
  3. How to Fix Error 20, The Memory Card: 步骤 3 中的图像 1,1
    • Remove the memory card and wait 30 seconds.
    • Put the memory card back in.
  4. How to Fix Error 20, The Power: 步骤 4 中的图像 1,1
    • Turn the power off and wait 30 seconds.
    • Turn the power back on.
  5. How to Fix Error 20, The Shutter: 步骤 5 中的图像 1,1
    • If a shutter can be found to be purchased individually, replace the Shutter.
    • Be careful to not touch the mirror. You will leave fingerprints.
结论
3等其他人完成本指南。
Sean
于09/17/14注册
189 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-4, Duarte Fall 2014 UMass Dartmouth, Team 1-4, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G4
3 名成员
创作了4篇指南
一条评论
This is not a fix (except for possibly replacing the shutter) this will only get your camera to work temporarily.
Fingerprints on the mirror is nothing to stress about. The mirror is only there to send the image up towards the EVF.
Johnny - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,203
