跳转到主内容
How to Fix E-Paper Tearing
你所需要的
  1. How to Fix E-Paper Tearing, Device: 步骤 1 中的图像 1,2 How to Fix E-Paper Tearing, Device: 步骤 1 中的图像 2,2
    • This is a guide to fix the E-Paper tearing in Pebble 301BL devices.
    • The Pebble Kickstarter Edition doesn't have screws, it is glued and therefore not repairable without permanent damage.
  2. How to Fix E-Paper Tearing, Remove screws: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    T5 Torx Screwdriver
    $5.49
    • Using a T5 Torx screwdriver, remove the 4 screws on the back.
    • When removing the back cover be very gentle! The rumble motor may be adhered to the cover so you must pry it away.
    • iFixit T5 Torx screwdriver
  3. How to Fix E-Paper Tearing, Video connector: 步骤 3 中的图像 1,1
    • Locate the video connector near the bottom, right next to the device that vibrates when you get a notification.
    • During normal use, this cable becomes loose and creates the tearing effect.
    • In the next step, you will be shown a way to apply pressure to this and keep it constantly connected.
  4. How to Fix E-Paper Tearing, Apply pressure to Video Connector: 步骤 4 中的图像 1,1
    • What worked for me is taking a little toilet tissue or paper towel and placing it over the video connector.
    • One way to test that this will help is by holding a finger on it and cycling through the menus.
    • Nothing inside the device will catch the paper on fire, so there is nothing to worry about.
  5. How to Fix E-Paper Tearing, Closing: 步骤 5 中的图像 1,1
    • Once you have confirmed that the paper will apply the necessary pressure, you can then put the screws back in.
    • If the case doesn't seem to close properly as it did before, do not keep on trying to tighten the screw down; you will strip the screw.
    • If the case doesn't close properly, you will need to open the device back up and remove a tiny bit of the paper until it does close, that way it will retain its water resistance.
    • Here is an example of the final result.
结论
40等其他人完成本指南。
9指南评论
This guide sadly only works for the revised model. The kickstarter edition had no screws in the back and have to be pried open from the screen, making the repair next to impossible without badly damaging de case or/and the screen.
gabrielcbnetto - 回复
Would something like the iopener work for that? Have had just about every model bar the original ks edition so im not sure myself.
Jayden Waters -
It is possible with heat and a ton of patients. Took a buddy of mine a whole afternoon to open it. Once he had the connector reseated, he actually used a of some sort to hold it in place instead so he wouldn't have to have the whole Pebble stuffed. Then he used the same putty/glue to help seal the watch shut. I'll see if he'll tell me what it was.
Zach Hillebrant - 回复
"To reassemble your device, follow these instructions in reverse order." .... so take it apart again and remove the tissue?
mlvezie - 回复
I see you are trying to be funny.
In case you were serious: no do not remove the tissue.
Benjamin Cunliffe -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 80
总计 9,160
