跳转到主内容
How to Fix Cat Scratches on a Leather Couch
你所需要的
  1. How to Fix Cat Scratches on a Leather Couch, How to Fix Cat Scratches on a Leather Couch: 步骤 1 中的图像 1,3 How to Fix Cat Scratches on a Leather Couch, How to Fix Cat Scratches on a Leather Couch: 步骤 1 中的图像 2,3 How to Fix Cat Scratches on a Leather Couch, How to Fix Cat Scratches on a Leather Couch: 步骤 1 中的图像 3,3
    • Apply a small amount of the 50% isopropyl rubbing alcohol to a paper towel or cloth.
    • Wipe down the damaged area of the leather with the rubbing alcohol.
    • Refrain from rubbing too aggressively as this can further damage the couch.
  2. How to Fix Cat Scratches on a Leather Couch: 步骤 2 中的图像 1,1
    • Move a spatula/scraper up and down over the scratches to determine the gradient (the way they open).
    • Opt for a plastic or rubber spatula rather than a metal one.
  3. How to Fix Cat Scratches on a Leather Couch: 步骤 3 中的图像 1,3 How to Fix Cat Scratches on a Leather Couch: 步骤 3 中的图像 2,3 How to Fix Cat Scratches on a Leather Couch: 步骤 3 中的图像 3,3
    • Apply glue to the spatula/scraper and spread it over the damaged area on the couch.
    • Ensure the scratches are fully saturated in this step.
    • Refrain from pushing too hard with the tool as this can increase the size of the scratches.
  4. How to Fix Cat Scratches on a Leather Couch: 步骤 4 中的图像 1,2 How to Fix Cat Scratches on a Leather Couch: 步骤 4 中的图像 2,2
    • Push the spatula/scraper toward the gradient of the scratches, closing them, and removing excess glue.
    • Wait for the glue to fully dry before moving to the next step.
    • A hairdryer may be used in this step to speed up the drying process.
  5. How to Fix Cat Scratches on a Leather Couch: 步骤 5 中的图像 1,3 How to Fix Cat Scratches on a Leather Couch: 步骤 5 中的图像 2,3 How to Fix Cat Scratches on a Leather Couch: 步骤 5 中的图像 3,3
    • Use the available colors in the dye kit with the paintbrush to spot-treat the repaired area.
    • Use light coats with this process for a clean and thorough application.
    • Let the product fully dry before moving to the next step.
    • This step can take 1-3 hours of waiting time for the product to dry.
    • Avoid touching the repaired area while it is drying.
  6. How to Fix Cat Scratches on a Leather Couch: 步骤 6 中的图像 1,2 How to Fix Cat Scratches on a Leather Couch: 步骤 6 中的图像 2,2
    • Before proceeding, you may use an 800-grit section of sandpaper to gently remove stiff or spiked remnants of color.
    • Apply 50% isopropyl alcohol to a paper towel or cloth.
    • Gently move over mistakes or areas with excess color.
    • The rubbing alcohol will remove more color if used in abundance or if too much pressure is applied during this step.
  7. How to Fix Cat Scratches on a Leather Couch: 步骤 7 中的图像 1,2 How to Fix Cat Scratches on a Leather Couch: 步骤 7 中的图像 2,2
    • The following steps are optional depending on the overall condition of the couch.
    • Apply a small amount of leather conditioner to a microfiber towel.
    • Work into the couch using circular motions, ensuring the product is massaged into the leather.
    • Depending on the location of the damage, allow 2-4 hours for the product to be absorbed into the leather before using the couch.
  8. How to Fix Cat Scratches on a Leather Couch: 步骤 8 中的图像 1,1
    • Observe the finished product. Determine whether the leather surface is adequately scratch-free.
    • If the area needs more attention, repeat steps 1-7 accordingly.
结论
Once the dye has dried and the leather conditioner applied, the couch will be repaired to its former glory.
Sophia Boerner
于02/20/24注册
157 声望
撰写一个指南
团队
Arizona-Cools Stephens-S24S2G5 Arizona-Cools Stephens-S24S2G5 的会员
Local Repair Groups
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 75
总计 148
