当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use a pry bar to remove the pre-existing damaged wood pieces.
Start with the riser first.
Be mindful of possible rusted screws/nails.
Remove the treads on the stairs.
Use a measuring tape to measure the foundation where the new steps will be placed.
To ensure accurate measurements, make sure to repeat this step twice.
Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
For the best results, use a ruler to connect your marks into a straight line.
Use a circular saw to cut across the straight line marked on the new piece of wood.
Make sure the wood is secure by holding the end resting on the table the entire time.
Safety glasses should be worn during this step.
Secure your wood piece (riser) into place using a drill and galvanized screws.
Create two pilot holes with the correct drill bit.
Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
Make sure your wood piece (tread) fits into place and is level.
For the most accurate results, it is important to use a large level.
Secure your wood piece (tread) into place using a drill and galvanized screws.
Create three pilot holes with the correct drill bit.
Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
Repeat steps 8-10 for the remaining stairs.
For the best results, follow this guide thoroughly for each stair.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
