跳转到主内容
How to Fix Broken Porch Entry Stairs
你所需要的
  1. How to Fix Broken Porch Entry Stairs, Stair treads and risers: 步骤 1 中的图像 1,3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: 步骤 1 中的图像 2,3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: 步骤 1 中的图像 3,3
    • Use a pry bar to remove the pre-existing damaged wood pieces.
    • Start with the riser first.
    • Be mindful of possible rusted screws/nails.
  2. How to Fix Broken Porch Entry Stairs: 步骤 2 中的图像 1,3 How to Fix Broken Porch Entry Stairs: 步骤 2 中的图像 2,3 How to Fix Broken Porch Entry Stairs: 步骤 2 中的图像 3,3
    • Remove the treads on the stairs.
  3. How to Fix Broken Porch Entry Stairs: 步骤 3 中的图像 1,2 How to Fix Broken Porch Entry Stairs: 步骤 3 中的图像 2,2
    • Use a measuring tape to measure the foundation where the new steps will be placed.
    • To ensure accurate measurements, make sure to repeat this step twice.
  4. How to Fix Broken Porch Entry Stairs: 步骤 4 中的图像 1,3 How to Fix Broken Porch Entry Stairs: 步骤 4 中的图像 2,3 How to Fix Broken Porch Entry Stairs: 步骤 4 中的图像 3,3
    • Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
    • For the best results, use a ruler to connect your marks into a straight line.
  5. How to Fix Broken Porch Entry Stairs: 步骤 5 中的图像 1,1
    • Place the new piece of wood onto the end of a sturdy table.
    • Make sure the marked end is hanging off the edge by at least a foot.
  6. How to Fix Broken Porch Entry Stairs: 步骤 6 中的图像 1,1
    • Use a circular saw to cut across the straight line marked on the new piece of wood.
    • Make sure the wood is secure by holding the end resting on the table the entire time.
    • Safety glasses should be worn during this step.
  7. How to Fix Broken Porch Entry Stairs: 步骤 7 中的图像 1,2 How to Fix Broken Porch Entry Stairs: 步骤 7 中的图像 2,2
    • Place the new piece of wood (riser) on the steps to ensure that it fits.
    • Use a leveler to make sure that it is level.
  8. How to Fix Broken Porch Entry Stairs: 步骤 8 中的图像 1,3 How to Fix Broken Porch Entry Stairs: 步骤 8 中的图像 2,3 How to Fix Broken Porch Entry Stairs: 步骤 8 中的图像 3,3
    • Secure your wood piece (riser) into place using a drill and galvanized screws.
    • Create two pilot holes with the correct drill bit.
    • Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  9. How to Fix Broken Porch Entry Stairs: 步骤 9 中的图像 1,1
    • Make sure your wood piece (tread) fits into place and is level.
    • For the most accurate results, it is important to use a large level.
  10. How to Fix Broken Porch Entry Stairs: 步骤 10 中的图像 1,3 How to Fix Broken Porch Entry Stairs: 步骤 10 中的图像 2,3 How to Fix Broken Porch Entry Stairs: 步骤 10 中的图像 3,3
    • Secure your wood piece (tread) into place using a drill and galvanized screws.
    • Create three pilot holes with the correct drill bit.
    • Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  11. How to Fix Broken Porch Entry Stairs: 步骤 11 中的图像 1,1
    • Repeat steps 8-10 for the remaining stairs.
    • For the best results, follow this guide thoroughly for each stair.
结论
To reassemble your old stairs, follow these instructions in reverse order.
另外一个人完成了本指南。
Kayla Unsworth
于01/19/18注册
240 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 135
总计 8,352
