跳转到主内容
How to Fix Broken Crayons
你所需要的
  1. How to Fix Broken Crayons, How to Fix Broken Crayons: 步骤 1 中的图像 1,3 How to Fix Broken Crayons, How to Fix Broken Crayons: 步骤 1 中的图像 2,3 How to Fix Broken Crayons, How to Fix Broken Crayons: 步骤 1 中的图像 3,3
    • Peel off the paper wrapper on all of the crayon pieces.
  2. How to Fix Broken Crayons: 步骤 2 中的图像 1,3 How to Fix Broken Crayons: 步骤 2 中的图像 2,3 How to Fix Broken Crayons: 步骤 2 中的图像 3,3
    • Boil water to 212°F/100°C.
    • A kettle is recommended for more control when pouring.
  3. How to Fix Broken Crayons: 步骤 3 中的图像 1,3 How to Fix Broken Crayons: 步骤 3 中的图像 2,3 How to Fix Broken Crayons: 步骤 3 中的图像 3,3
    • Cut a piece of aluminum foil about 6x2 inches.
    • Fold the 6 inch side of foil in half.
    • Fold up all four sides of the foil to create a thin rectangle, about 1 inch away from the edges.
  4. How to Fix Broken Crayons: 步骤 4 中的图像 1,3 How to Fix Broken Crayons: 步骤 4 中的图像 2,3 How to Fix Broken Crayons: 步骤 4 中的图像 3,3
    • Pinch up the corners of the foil by following the folded creases made in the last step.
    • Repeat this step for all four corners.
  5. How to Fix Broken Crayons: 步骤 5 中的图像 1,3 How to Fix Broken Crayons: 步骤 5 中的图像 2,3 How to Fix Broken Crayons: 步骤 5 中的图像 3,3
    • Insert the broken crayon pieces into the foil mold.
  6. How to Fix Broken Crayons: 步骤 6 中的图像 1,3 How to Fix Broken Crayons: 步骤 6 中的图像 2,3 How to Fix Broken Crayons: 步骤 6 中的图像 3,3
    • Place mold into a heat-safe container.
    • While holding onto the mold, carefully pour in boiling water up to the rim of the mold.
    • Your mold may float in the water or tilt to one side while water is being poured.
    • Wait for the wax to fully melt.
    • Be careful when handling hot materials.
  7. How to Fix Broken Crayons: 步骤 7 中的图像 1,3 How to Fix Broken Crayons: 步骤 7 中的图像 2,3 How to Fix Broken Crayons: 步骤 7 中的图像 3,3
    • Take the mold out of the water once cooled.
    • When wax has moderately hardened, loosen the sides of the foil from the wax.
    • Cut a corner of the foil mold and unwrap the crayon.
    • Leave the newly created crayon in a cool and dry area overnight to fully solidify before use.
终点
Madeline Furtado
于05/12/25注册
145 声望
撰写一个指南
团队
UC Davis, Team 2-8, Whithaus Spring 2025 UC Davis, Team 2-8, Whithaus Spring 2025 的会员
UCD-WHITHAUS-S25S2G8
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 29
总计 365
