跳转到主内容
How to Fix Bent Silverware
你所需要的
  1. How to Fix Bent Silverware, How to Fix Bent Silverware: 步骤 1 中的图像 1,2 How to Fix Bent Silverware, How to Fix Bent Silverware: 步骤 1 中的图像 2,2
    • First, clean with soap and water all of the bent silverware.
  2. How to Fix Bent Silverware: 步骤 2 中的图像 1,1
    • Take the pot and fill it halfway with water.
    • Put the pot on the stove and heat the water till it's boiling.
  3. How to Fix Bent Silverware: 步骤 3 中的图像 1,1
    • Place the bent silverware in the water for at least one minute.
  4. How to Fix Bent Silverware: 步骤 4 中的图像 1,1
    • After the minute is over, carefully pull out all of the silverware using pliers.
  5. How to Fix Bent Silverware: 步骤 5 中的图像 1,1
    • Dry off the silverware with either paper or cloth towels. Be careful not to burn yourself.
  6. How to Fix Bent Silverware: 步骤 6 中的图像 1,2 How to Fix Bent Silverware: 步骤 6 中的图像 2,2
    • Use tools such as pliers, a hard surface, rulers, and/or hammers to reshape silverware as desired.
  7. How to Fix Bent Silverware: 步骤 7 中的图像 1,1
    • When your done bending the silverware to its desired shape, let the silverware cool down to stay in that shape.
终点
4等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 3,806
