跳转到主内容
How to Fix A Stripped Screw Hole
你所需要的
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: 步骤 1 中的图像 1,1
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: 步骤 2 中的图像 1,2 How to Fix A Stripped Screw Hole: 步骤 2 中的图像 2,2
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: 步骤 3 中的图像 1,2 How to Fix A Stripped Screw Hole: 步骤 3 中的图像 2,2
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: 步骤 4 中的图像 1,1
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: 步骤 5 中的图像 1,1
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: 步骤 6 中的图像 1,2 How to Fix A Stripped Screw Hole: 步骤 6 中的图像 2,2
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
结论
Your screw should now hold secure.
Isaiah Valdez Mireles
于08/22/22注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 3-24, Briggs Fall 2022 CSU Los Angeles, Team 3-24, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S3G24
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 21
总计 2,005
