跳转到主内容
How to Fix A Squeaky Elliptical
你所需要的
  1. How to Fix A Squeaky Elliptical, How to Fix A Squeaky Elliptical: 步骤 1 中的图像 1,3 How to Fix A Squeaky Elliptical, How to Fix A Squeaky Elliptical: 步骤 1 中的图像 2,3 How to Fix A Squeaky Elliptical, How to Fix A Squeaky Elliptical: 步骤 1 中的图像 3,3
    • Test out your elliptical by swinging the cord side to side and listening for noise.
    • Is the squeaking coming from multiple locations or maybe just one screw? Most likely, it will be the coming from the connection between the bolt and the cord.
  2. How to Fix A Squeaky Elliptical: 步骤 2 中的图像 1,1
    • Use a general multi-purpose cleaner and a dry cloth or paper towel to remove dust and gunk from your machine.
  3. How to Fix A Squeaky Elliptical: 步骤 3 中的图像 1,1
    • Use compressed air to get rid of debris that is harder to reach, especially parts that cover the bolt and cords on your elliptical.
  4. How to Fix A Squeaky Elliptical: 步骤 4 中的图像 1,2 How to Fix A Squeaky Elliptical: 步骤 4 中的图像 2,2
    • Use WD-40 wherever two pieces connect to make sure there's no rubbing between parts. Make sure to get it deep in the corners and really saturate the metal.
    • You can also use it in places you think might get rustier over time or might collect moisture.
  5. How to Fix A Squeaky Elliptical: 步骤 5 中的图像 1,1
    • Use a cotton swab to apply grease to the bolts.
  6. How to Fix A Squeaky Elliptical: 步骤 6 中的图像 1,3 How to Fix A Squeaky Elliptical: 步骤 6 中的图像 2,3 How to Fix A Squeaky Elliptical: 步骤 6 中的图像 3,3
    • Test out your machine to make sure that it no longer squeaks by doing the same motions from Step 1. If your machine still makes noise, repeat Steps 3 through 5.
终点
另外一个人完成了本指南。
calvez18
于09/20/20注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 82
总计 5,424
