跳转到主内容
How to Fix A Loose RCA RT3205 TV Stand
你所需要的
  1. How to Fix A Loose RCA RT3205 TV Stand, How to Fix A Loose RCA RT3205 TV Stand: 步骤 1 中的图像 1,1
    • Place a soft cushioned material on top of a flat surface, like a table.
    • This is to prevent damaging the TV screen panel.
    • Make sure your path towards the TV is clear of any obstructions. If not, remove all obstacles.
  2. How to Fix A Loose RCA RT3205 TV Stand: 步骤 2 中的图像 1,3 How to Fix A Loose RCA RT3205 TV Stand: 步骤 2 中的图像 2,3 How to Fix A Loose RCA RT3205 TV Stand: 步骤 2 中的图像 3,3
    • Unplug the TV set from the power supply.
    • Keep TV set unplugged until repair is completed.
    • Failure to unplug the TV can result in a hazardous situation which, if not avoided, could result in death or serious injury.
  3. How to Fix A Loose RCA RT3205 TV Stand: 步骤 3 中的图像 1,1
    • Place the TV monitor flat on top, with the screen side facing down.
  4. How to Fix A Loose RCA RT3205 TV Stand: 步骤 4 中的图像 1,1
    • Align the stand(s) onto the bottom of the TV.
    • If the stands have been installed already, remove them and realign.
  5. How to Fix A Loose RCA RT3205 TV Stand: 步骤 5 中的图像 1,2 How to Fix A Loose RCA RT3205 TV Stand: 步骤 5 中的图像 2,2
    • Align the screw holes on the stand and to the bottom of the TV.
  6. How to Fix A Loose RCA RT3205 TV Stand: 步骤 6 中的图像 1,1
    • Gently tighten the screws with a screwdriver to fasten the stand to the panel.
    • A table knife can be used in place of a screwdriver.
结论
另外一个人完成了本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 852
