跳转到主内容
How to Fix A Broken Makeup Compact Without Alcohol
你所需要的
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: 步骤 1 中的图像 1,1
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: 步骤 2 中的图像 1,1
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: 步骤 3 中的图像 1,1
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: 步骤 4 中的图像 1,2 How to Fix A Broken Makeup Compact Without Alcohol: 步骤 4 中的图像 2,2
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: 步骤 5 中的图像 1,3 How to Fix A Broken Makeup Compact Without Alcohol: 步骤 5 中的图像 2,3 How to Fix A Broken Makeup Compact Without Alcohol: 步骤 5 中的图像 3,3
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: 步骤 6 中的图像 1,3 How to Fix A Broken Makeup Compact Without Alcohol: 步骤 6 中的图像 2,3 How to Fix A Broken Makeup Compact Without Alcohol: 步骤 6 中的图像 3,3
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: 步骤 7 中的图像 1,3 How to Fix A Broken Makeup Compact Without Alcohol: 步骤 7 中的图像 2,3 How to Fix A Broken Makeup Compact Without Alcohol: 步骤 7 中的图像 3,3
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
终点
Cura Mclemore
于03/21/23注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 416
