跳转到主内容
简介
This guide will show you how to fix the “Staingate” issue on Apple MacBook displays. Staingate happens when the anti-reflective coating on certain models of MacBook displays begins to delaminate and wear off, causing a stain-like appearance that is noticeable when the screen is off, on a low brightness setting, or when sunlight is hitting the screen. Staingate is a very widespread issue, and many people unfortunately end up replacing the display or even the entire MacBook because of it. This guide will fix the Staingate issue and make the display look brand new.
  1. How to Fix “Staingate” on Apple MacBook Displays, How to Fix “Staingate” on Apple MacBook Displays: 步骤 1 中的图像 1,2 How to Fix “Staingate” on Apple MacBook Displays, How to Fix “Staingate” on Apple MacBook Displays: 步骤 1 中的图像 2,2
    • Dampen a microfiber cloth with water.
    • Use the cloth to clean the screen of dust and debris.
  2. How to Fix “Staingate” on Apple MacBook Displays: 步骤 2 中的图像 1,2 How to Fix “Staingate” on Apple MacBook Displays: 步骤 2 中的图像 2,2
    • Put on latex gloves.
    • Dampen a separate microfiber cloth with Listerine or white vinegar.
  3. How to Fix “Staingate” on Apple MacBook Displays: 步骤 3 中的图像 1,1
    • Wipe the screen with the damp vinegar/Listerine cloth in a circular motion.
    • Make sure you have gloves on during this step as the anti-reflective coating on the MacBook screen releases chemicals that could be absorbed through the skin.
  4. How to Fix “Staingate” on Apple MacBook Displays: 步骤 4 中的图像 1,2 How to Fix “Staingate” on Apple MacBook Displays: 步骤 4 中的图像 2,2
    • You may have to wipe the screen a second time as some stains can be stubborn.
    • Apply more Listerine or white vinegar onto the cloth as needed.
    • Remember to keep your gloves on.
  5. How to Fix “Staingate” on Apple MacBook Displays: 步骤 5 中的图像 1,2 How to Fix “Staingate” on Apple MacBook Displays: 步骤 5 中的图像 2,2
    • Dampen the first microfiber cloth with water again.
    • Wipe the screen free of debris with the cloth.
    • You can remove your gloves at this step.
  6. How to Fix “Staingate” on Apple MacBook Displays: 步骤 6 中的图像 1,1
    • Install the new screen protector on your MacBook screen to minimize glare and to get some of the anti-reflectiveness back.
结论
Staingate should not occur again as long as you install a reputable screen protector afterwards.
另外一个人完成了本指南。
Chun-Ho Lee
于2021年09月23日注册
157 声望分
撰写一个指南
团队
York University, Team G-15, O'Regan Fall 2021 York University, Team G-15, O'Regan Fall 2021 的会员
YORK-O'REGAN-F21SGG15
1 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 61
过去的7天: 420
过去的30天: 1,743
总计 5,964
