简介
本指南将告诉你如何修复 Apple MacBook 显示屏上的 “涂层脱落”问题。当某些型号的 MacBook 显示屏上的防反射涂层开始脱层和磨损时,就会出现 “涂层脱落”现象,当屏幕关闭、亮度设置较低或阳光照射到屏幕时,就会出现明显的污点。“涂层脱落”是一个非常普遍的问题,许多人最终都会因此而更换显示屏甚至整个 MacBook。本指南将修复“涂层脱落”问题,让显示屏焕然一新。
你所需要的
只要事后安装一个值得信任的屏幕保护膜,就不会再出现“涂层脱落”。
16等其他人完成本指南。
由衷感谢以下译者:
100%
SuooL正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
22条评论
Ist es möglich, das Glas auszubauen? Ich habe ein MacBookPro11,4 – MacBook Pro (Retina, 15', Mitte 2015).
Followed instructions provided and used cleaning vinegar. Took a while and repeated rubbing of some areas with fresh vinegar, but end result very good and screen as new. Only in two bottom corners either pressed too hard or got some fluid behind the glas that shows up on the display with different “wet” colors. Hope that over time - if it is fluid - this will evaporate/disappear. But still happy with results as it so much improved. Thanks for sharing this approach.
Can confirm that few days later the “wet” colors in bottom corners have completely disappeared. This approach completely fixed the “staingate” issue for us. Thanks.
Thanks for the instructions! Works perfectly on our MBP early 2015.
Sue and Sergio
