跳转到主内容
How to Fast Fix a sharp edge on a garage door
你所需要的
  1. How to Fast Fix a sharp edge on a garage door, How to Fast Fix a sharp edge on a garage door: 步骤 1 中的图像 1,2 How to Fast Fix a sharp edge on a garage door, How to Fast Fix a sharp edge on a garage door: 步骤 1 中的图像 2,2
    • Disconnect the garage door from the power supply.
  2. How to Fast Fix a sharp edge on a garage door: 步骤 2 中的图像 1,2 How to Fast Fix a sharp edge on a garage door: 步骤 2 中的图像 2,2
    • Spray the cleaning solution on the sharp edge of the garage door railing and the metal file.
  3. How to Fast Fix a sharp edge on a garage door: 步骤 3 中的图像 1,1
    • Remove the debris from the sharp edge of the garage door using a brush.
  4. How to Fast Fix a sharp edge on a garage door: 步骤 4 中的图像 1,3 How to Fast Fix a sharp edge on a garage door: 步骤 4 中的图像 2,3 How to Fast Fix a sharp edge on a garage door: 步骤 4 中的图像 3,3
    • Use the metal file to bevel the sharp edge of the garage door by grinding against it in a curved motion.
  5. How to Fast Fix a sharp edge on a garage door: 步骤 5 中的图像 1,1
    • Use the metal brush to clear the debris from the beveled edge.
  6. How to Fast Fix a sharp edge on a garage door: 步骤 6 中的图像 1,2 How to Fast Fix a sharp edge on a garage door: 步骤 6 中的图像 2,2
    • Clean the beveled edge using the rag and the cleaning solution.
结论
Assess the sharpness of the edge and bevel further if necessary.
Dylan Thompson
于09/19/22注册
133 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 43
