跳转到主内容
How to Fast Fix a Crack on Granite Countertop
你所需要的
  1. How to Fast Fix a Crack on Granite Countertop, How to Fast Fix a Crack on Granite Countertop: 步骤 1 中的图像 1,1
    • Ensure the surface to be cured is clean and dry.
    • When epoxies are mixed, the compound hardens rapidly. Before mixing, it is crucial to prepare the surface for repairs and to mix just enough to get the job done.
  2. How to Fast Fix a Crack on Granite Countertop: 步骤 2 中的图像 1,3 How to Fast Fix a Crack on Granite Countertop: 步骤 2 中的图像 2,3 How to Fast Fix a Crack on Granite Countertop: 步骤 2 中的图像 3,3
    • Measure and mix an equal proportion of hardener and resin.
    • For a good curing effect, epoxy resin and hardener should be measured out in a 1:1 ratio.
    • Epoxy resins are safe to use if managed appropriately. Do not swallow; may be poisonous if swallowed.
  3. How to Fast Fix a Crack on Granite Countertop: 步骤 3 中的图像 1,3 How to Fast Fix a Crack on Granite Countertop: 步骤 3 中的图像 2,3 How to Fast Fix a Crack on Granite Countertop: 步骤 3 中的图像 3,3
    • Add a small amount of tint to the hardener and resin.
    • Stir in until thoroughly mixed.
    • Tinting is optional when sealing or rejoining a piece of granite that has a clean split with no missing fragments.
    • Do not add too much tint!
  4. How to Fast Fix a Crack on Granite Countertop: 步骤 4 中的图像 1,3 How to Fast Fix a Crack on Granite Countertop: 步骤 4 中的图像 2,3 How to Fast Fix a Crack on Granite Countertop: 步骤 4 中的图像 3,3
    • Apply the mixture to the crack or damaged area.
  5. How to Fast Fix a Crack on Granite Countertop: 步骤 5 中的图像 1,2 How to Fast Fix a Crack on Granite Countertop: 步骤 5 中的图像 2,2
    • Tape the cured area with some painters tape.
    • It is optional to use the painters tape on a flat surface. The strip aids in molding the epoxy to precise curves.
    • Allow to dry for 30-45 minutes.
    • Before removing strip, lift and feel the epoxy, and ensure it is dry.
    • Once dried, slowly peel back the tape and shave off the dried excess with a putty knife.
  6. How to Fast Fix a Crack on Granite Countertop: 步骤 6 中的图像 1,3 How to Fast Fix a Crack on Granite Countertop: 步骤 6 中的图像 2,3 How to Fast Fix a Crack on Granite Countertop: 步骤 6 中的图像 3,3
    • Use a putty knife or a razor to scrape off excess epoxy.
    • For a visibly flat finish, it's best to use a razor to scrape off the dry epoxy.
  7. How to Fast Fix a Crack on Granite Countertop: 步骤 7 中的图像 1,2 How to Fast Fix a Crack on Granite Countertop: 步骤 7 中的图像 2,2
    • Depending on the product used, The finished surface may look glossy.
    • Apply a granite sealer over the area.
结论
Enjoy your crack free countertop!
2等其他人完成本指南。
Deborah Kalu
于07/01/23注册
172 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 81
总计 3,438
